    Hi i'm a total noob and have been trying to get infor on buying a mini milling machine and turning it into cnc.
    Im looking at buying a Shirline milling machine, it's size is right for what i need it for. Has anyone used these?
    I would like to convert it to cnc with a ready to go or plug and play kits as it were, I believe these are available for this machine, roughly how much would these kits cost? I know these use NEMA #23 motors.
    I dont want to write code initially or do i have to, to make cnc parts? Can the software generate the programming code for me?
    I have Rhino2 from years ago, i have no problem with making 3D images with graphics software or computers.
    Sorry for the questions i have so many.
  2. Quote Originally Posted by jsa2001 View Post
    Hi jsa2001
    Google is your friend... or see [ame="http://www.mycncuk.com/forums/showthread.php?t=349"]this thread[/ame]
    Basically a CNC Kit for a CNC-ready Sherline Mill is around $250 or about the same in GBP once shipped into UK. You might be better off buying the thing ready-converted as it may be cheaper (unless you are buying a secondhand mill)
    There are various software routes, programming is not required (but worth learning). Have a browse through the pages of this forum to get some ideas, there are several threads on the subject.
    Hi jsa2001
    Google is your friend... or see this thread
    Thanks i've had a quote from a UK supplier for a retrofitting sherline cnc kit it comes to more 3 times the cost of the same kit sold in the USA. JUST SHORT OF £800, does that seem correct?
    Is that £800 for just the mechanical parts or does that include the motors, drivers etc??
    Quote Originally Posted by HiltonSteve View Post
    Hi here's a breakdown 3 stepper motors at £75.25 each, control box £576
    £220 for the motor adapters or £835 with the adaptors already on the mill ready to receive the cnc kit.
    That seems mighty expensive for 3 steppers and a control box, check this out - http://www.diycnc.co.uk/html/cnc_systems.html
    I used 5A Driver50's for my machine (Router) with 3 x 3.1Nm (5A) 23 size steppers, got the whole electronic kit from Roy (DIYCNC) which also included a 36V PSU and breakout board for just over £300. The only thing you will need is a box to put them all in, I made my own but one or two people use PC cases, wiring them up is a piece of cake. Check out my build log which may give you a few ideas. [ame="http://www.mycncuk.com/forums/showthread.php?t=1058"]My Build - I blame you lot for this....! - MYCNCUK[/ame]
    What power are the steppers that they are offering?
ID:	936   Click image for larger version.
    Think they might be these.http://www.sherline.com/67127pg.htm
    The quote i got is from a Sherline dealer over here. MillHill supplies.
    Im usless at electrics but can build pc's and problem solve them.
    Your system looks really neat and well set out as i said not to sure how to wire the whole thing up.
    Check this out, may be right up your street. Don't know anyone that has got one but Roy would not be selling crap. http://www.diycnc.co.uk/html/system4.html. Very little wiring to do on this one.
    2.5A drivers
    3.1Nm steppers
    Modular design - much less wiring
    With Power supply - £250
    All you will need is a box to put it in, not a very big one either by the looks of it!
    But if you do go for something that needs more wires then don't worry about it, wiring drivers, steppers breakout boards is a lot easier than you think. Wiring by numbers most of the time, took me an hour to get mine up and running on the bench and that was my first attempt!
    Thats with stepper motors correct? I might give him a bell.
    I might by the sherline mill with mounts and stepper motors and just use it manually for a while then fit a kit like the one you posted.
  1. What tooling to drill lots of 10mm holes 45mm deep?
    By AlanMJackson in forum Tool & Tooling Technology
    Last Post: 13-01-2014, 08:53 PM
  2. Replies: 3
    Last Post: 25-06-2013, 08:30 AM
  3. Ridges in 3D profiles = hair loss and lots sandpaper
    By Shinobiwan in forum Machine Discussion
    Last Post: 11-04-2013, 07:45 PM
  4. FOR SALE: Lots of Bosch Rexroth Aluminium extrusion 50mm x 50mm.
    By michael in forum Items For Sale
    Last Post: 12-10-2011, 08:52 AM
