    The short answer is, no you can't get what you want for 30 - 50k. That budget would only cover a 2 axis machine, at about the 50k mark, of course prices vary pending manufacturer and machine spec. For a C axis single spindle, single turret you are looking in the region of 80k of course this is only a very crude guide and numbers are ball parks. More spindles and turrets and the price rockets because those machines are true one hit machining.
    A good channel to follow is MTD CNC on Youtube. They cover new machines on the market, offers from suppliers and end user interviews, there is a lot of info to be had from these vids but i can't say i rate the majority of there interviewers. It comes under 'the could do better category' but if you can ignore that part as i have, then the info is good.
    I can rattle off a load of manufactures but without the budget you may need to re-evaluate what you are looking for. Second hand is your only real option in that budget range unless you get really lucky of course.
    Thank you for the help. This is exactly the kind of direction I was looking for. We will have to either come up with more money or re-evaluate our needs. I will check out the MTD CNC channel as well.
  1. Lathe transporter reccomendations
    By Fenza in forum General Discussion
    Last Post: 27-11-2018, 06:12 PM
  2. PCB Milling reccomendations
    By PEU in forum Machine Discussion
    Last Post: 15-12-2017, 12:53 PM
  3. Small footprint turning centre
    By Hellfire in forum Marketplace Discussion
    Last Post: 28-08-2013, 10:13 PM
  4. Centre tap transformer?
    By veedub1955 in forum General Electronics
    Last Post: 15-05-2012, 11:10 PM
  5. Turning centre retrofit help/project on a Mazak/Yamazaki
    By spluppit in forum Mazak, Yamazaki Lathes
    Last Post: 13-11-2010, 01:43 AM
