Thread: gritty ballscrews
Yep, I can't access the attachments either.
Get message "Invalid Attachment specified. If you followed a valid link, please notify the administrator"
27-01-2019 #2
I don't know what happened to the pics, they were there when I checked the post. I've put them up again, take a peek before they disappear again!
01-02-2019 #3
Well, I got a very apologetic email back from Fred, apparently they were rather rushed getting stuff out before Chinese New Year. He's suggested removing the seals and flushing through, apparently this works a lot of the time and is obviously easier than complete dis-assembly.
02-02-2019 #5
I'm going to try the flushing thing, I know what they should feel like when put together properly and if they don't meet that it'll be a complete strip down :-( . If nothing else, cleaning out some of the crap will make winding the nuts down to get the balls out less graunchy.
BTW, what would be the recommended oil/grease to use when re-assembling?Last edited by Voicecoil; 03-02-2019 at 01:14 PM.
Hows things going with these screws? Had any luck?
If you're still looking for oil/grease recommendations, Lee gave me a great reply recently - the short version being lithium based grease - if you look at the HIWIN greasing guide, you'll also see EP1 mentioned.
http://www.mycncuk.com/threads/11552...y?goto=newpost
25-02-2019 #7
Yes, Fred has been good to his word and sorted me out with some replacement bits including completely replacing the 1204 screws which had the slightly wonky end machining - you can't fault the guy's service, 10/10. Regarding the grease, looking at the specs Hiwin recommend, I've realised that I already have something that should do - Mobil 1, which I bought for re-packing the struts on the car.
machining ballscrews
By T0rnado69 in forum Lead Screws, Nuts & SupportsReplies: 11Last Post: 13-04-2014, 11:39 PM -
Best place to get ballscrews?
By Ross77 in forum Lead Screws, Nuts & SupportsReplies: 6Last Post: 15-04-2013, 10:09 PM -
machined ballscrews
By wilfy in forum Lead Screws, Nuts & SupportsReplies: 15Last Post: 30-07-2012, 05:42 PM -
Two ballscrews on both X and Y axis?
By Jonathan in forum Gantry/Router Machines & BuildingReplies: 2Last Post: 02-02-2012, 01:55 AM -
supports for ballscrews
By leadinglights in forum Lead Screws, Nuts & SupportsReplies: 2Last Post: 27-04-2010, 12:31 PM
