    Hello,
    Sorry for I am a newbie on CNC...
    I am trying to connect a motor driver with 4 wires names: DIR+, DIR-, PUL+ and PUL- to a control board that only have 3 wires: Axis_enable, DIR and STEP...
    I am missing something, are these not compatible or is it that DIR- and PUL- should be grounded and STEP=PUL+ with DIR=DIR+?
    Thanks!
    Cyrille
    Quote Originally Posted by brebisson View Post
    Hello,
    Thanks!
    Cyrille
    Welcome to the forum Cyrille. Depending on the BOB you have usually you would have STEP=PUL+ with DIR=DIR+ both connected to 5V+ and STEP=PU- and Dir- going to the BOB
  3. ...and you can leave the axis-enable output from the from the BOB disconnected. Usually drivers are configured so that if you do not connect "enable" then the driver is enabled so a lot of people do not use the "enable" signal at all. However, in this case it sounds as if your driver does not have an "enable" input anyway so you only need to connect the step and direction wires as Clive has suggested.
  1. PWM control for single AC motor?
    By AcrimoniousMirth in forum Control Hardware & Systems
    Last Post: 07-04-2018, 11:01 AM
  2. Please help me with step motor choice.
    By Toolman321 in forum Stepper & Servo Motors
    Last Post: 08-06-2017, 10:02 AM
  3. Closed loop Step Servo Drive Driver 2HSS86H + 4.5N.M Motor + Encoder
    By george uk in forum Motor Drivers & Controllers
    Last Post: 23-06-2014, 08:38 PM
  4. single and 3 phase motor sizing and mounting ?
    By Musht in forum General Electronics
    Last Post: 27-10-2013, 09:58 PM
  5. Help Make 1st Step - Wiring Up Drivers to Motor and Arduino
    By Treemonkey in forum General Electronics
    Last Post: 25-04-2013, 05:47 PM
