    I am trying to make a powered draw bar for a Novamill BT30 what is the correct angle for the stud? The collect will have 5 1/4" balls
    Lives in East Lothian, United Kingdom. Last Activity: 2 Hours Ago Forum Superstar, has done so much to help others, they deserve a medal. Has a total post count of 2,984. Received thanks 369 times, giving thanks to others 9 times.
    30 (or 60 depending where you take the reference from) degrees.
    http://www.denfordata.com/bb/viewtop...p=19429#p19429
    Thanks. I had seen that thread before some time ago but forgot where it was I probably have bought the wrong one then.
    https://www.ebay.co.uk/itm/110222-BT...72.m2749.l2649
    Its not come yet do you recon the above would work?
    My guess would be the 45 deg taper is likely to not lock as strongly as the 30deg, and might possibly push the gripper balls back under high/interrupted cuts.
    Cutwel have the correct studs listed - https://www.cutwel.co.uk/tool-holdin...-stud-standard
    I did also find an Indian company last week who had through coolant studs listed at a cheaper price - https://www.toolsengg.com/ps-bt30-45-deg-w-tc.html
    Only reason I currently know the spec, is I'm looking for a batch for some new tool holders I've got ordered for my Triac.
    Thanks I knew you would know.. I have found these
    https://www.ebay.co.uk/itm/2Pcs-BT30...72.m2749.l2649
    Those should do.
    I've just bit the bullet and ordered a batch of BT35 ER toolholders with pull studs, as trying to juggle the existing mish mash of holders and collets finally broke me last week when I wanted to add a new cutter. Just need to wait a couple months for them to be delivered now..
  1. BT30 Ebay spindle
    By pnub93 in forum General Discussion
    Last Post: 16-01-2019, 04:05 PM
  2. BT30 in an R8 spindle?
    By Ross77 in forum Tool & Tooling Technology
    Last Post: 07-07-2018, 08:51 AM
  3. Drawings, 1st Angle or 3rd Angle?
    Last Post: 12-05-2018, 02:26 PM
  4. Question regarding BT30 Tooling for a Denford
    By Chaz in forum Denford Mills
    Last Post: 04-06-2015, 10:49 PM
  5. ISO30 v BT30???
    By anamsey in forum Machine Discussion
    Last Post: 16-01-2013, 07:56 PM
