    I'm converting a similar machine from Chester Machine tools and found it's fairly cheap (around £5 each) to replace the lead screw end bearings with a quality brand from my local industrial bearing & seal supplier.
    Don't forget your oil delivery system to the ball nuts, it will significantly increase their working life.
    - Nick
    Y axis start.
    Picture 1 original X Y acme screw nuts
    picture 2 Ballscrew mounts on saddle. These are 15mm thick (from scrapbox) but 12mm should work.
    picture 3 Saddle with nut fitted. To fit to the mill base the mounts/nut must be removed from the saddle to the keeper(post 3 picture 7). After screw is located into the base, the nut and mounts can be attached. The keeper has a 10mm recess to fit the turned down end of the ballscrew to give alignment. The saddle can then be fitted and attached to the mounts with original 8mm screws.
    picture 4 Y axis ballscrew mounts
    picture 5 Y axis top view. All y axis parts are 10mm mild steel.
    picture 6 Y axis plate dimensions.
    picture 7 Y axis sides for motor mount. Length may be altered depending on coupling ans shaft lengths.
    Thats it for now
    Best Regards
    picclock
ID:	25424   Click image for larger version.
Name:	Ballscrew mounts.jpg
ID:	25426   Click image for larger version.
Name:	Fitted nut, facing rear.jpg
ID:	25425   Click image for larger version.
Name:	Y axis mounts.png
ID:	25423   Click image for larger version.
Name:	Y axis top.png
ID:	25422   Click image for larger version.
Name:	Y axis plate.png
ID:	25428   Click image for larger version.
Name:	Y axis sides.png
  1. Sieg/ARC X3 CNC mill conversion
    By Leadhead in forum Workshop & Equipment
    Last Post: 20-10-2018, 04:11 PM
  2. Weiss WMD25LV mill
    By Bill K in forum Milling Machines, Builds & Conversions
    Last Post: 29-06-2014, 12:52 PM
  3. CONVERSION: Sx3 mill conversion
    By dazza in forum Conversion Build Logs
    Last Post: 29-04-2014, 10:23 AM
  4. X3 Vs AMD 25LV (Weiss WMD 25LV) for CNC conversion
    By sebring115 in forum Milling Machines, Builds & Conversions
    Last Post: 18-11-2011, 12:20 PM
  5. Mill conversion to cnc
    By wolsey in forum General Discussion
    Last Post: 15-08-2011, 11:07 PM
