Thread: Weiss VM32 Mill Conversion
06-02-2019 #7
The 'conventional' method should use angular contact bearings, not deep groove bearings, which are far more suited to the purpose than a standard thrust bearing.
A basic thrust bearing gives very little radial support, so unless they're housed and adjusted perfectly, when spun at any speed your shaft/ball screw will likely whip, resulting in the kind of issue you are attempting to avoid. Any play in an angular contact should be noticeable in backlash long before damage from whipping become an issue, unlike a basic thrust bearing.Avoiding the rubbish customer service from AluminiumWarehouse since July '13.
Sieg/ARC X3 CNC mill conversion
By Leadhead in forum Workshop & EquipmentReplies: 4Last Post: 20-10-2018, 04:11 PM -
Weiss WMD25LV mill
By Bill K in forum Milling Machines, Builds & ConversionsReplies: 4Last Post: 29-06-2014, 12:52 PM -
CONVERSION: Sx3 mill conversion
By dazza in forum Conversion Build LogsReplies: 1Last Post: 29-04-2014, 10:23 AM -
X3 Vs AMD 25LV (Weiss WMD 25LV) for CNC conversion
By sebring115 in forum Milling Machines, Builds & ConversionsReplies: 1Last Post: 18-11-2011, 12:20 PM -
Mill conversion to cnc
By wolsey in forum General DiscussionReplies: 1Last Post: 15-08-2011, 11:07 PM
