06-02-2019 #3
A quick look at the accelerometer specs show it is probably not that useful for you. Max sampling is ~900 Hz which is not that high as max useable is ~450 Hz.
A 24,000 rpm spindle with 2 flute cutter gives 800 Hz for primary impact frequency and there will be higher frequency harmonics of that.
Only sampling for 0.1 seconds is not long enough to do sweeps plus don’t give long enough or FFT averaging over multiple frames.
As Voicecoil says this is just generating a time history and calculating overall simple parameters such as RMS. it is a simple remote health check for a machine with a known good level for RMS not a deep dive tool.
You need to have a longer time history and convert this into a frequency spectrum using FFT analysis. This can be done offline if the time signal is recorded onto something first or done live.
Then you can sweep the spindle and look for peaks then find out the vibration pattern causing this (mode shape) and fix it.
Or you do modal analysis but you need another channel to measure the force input (from a shaker or hammer)
This is a big topic and this answer is brief
ps3 wireless controller
By PAULRO in forum General ComputingReplies: 0Last Post: 29-12-2018, 04:10 PM -
Vibration, mass and massive arguments
By Rogue in forum Gantry/Router Machines & BuildingReplies: 6Last Post: 03-11-2014, 11:24 PM -
M542 driver - motor vibration at low speeds
By birchy in forum Motor Drivers & ControllersReplies: 34Last Post: 22-11-2013, 08:16 PM -
motor mount vibration vs torque'd bolts
By dsc in forum Gantry/Router Machines & BuildingReplies: 6Last Post: 22-10-2013, 10:36 AM -
A daft question about vibration damping
By D.C. in forum Gantry/Router Machines & BuildingReplies: 11Last Post: 11-10-2012, 09:57 AM
