Inside corners only.
But if you relieved the outside corners to a slightly larger radius there is no reason the gear wouldn't function perfectly, the "Point" and "Valley Bottom" on the gear where the two opposite angled tooth profiles join can be relieved significantly for clearance without affecting the function of the gear.
If you made a finishing pass for the inside corner with an engraving cutter you could actually get quite a sharp inside corner, you'd have to have good 4-axis CAM for that, and know how to use it too.You think that's too expensive? You're not a Model Engineer are you? :D
metal & lathe process question (newbie)
By JEK5019 in forum Machine DiscussionReplies: 7Last Post: 14-02-2019, 01:26 PM -
What software/process do I need to do this?
By IanParkin in forum Computer SoftwareReplies: 5Last Post: 23-06-2013, 04:47 PM -
A learning process
By cropwell in forum Milling Machines, Builds & ConversionsReplies: 5Last Post: 21-02-2013, 07:38 PM -
Why my company doesn't want to speed up the process?
By membermy in forum General DiscussionReplies: 3Last Post: 24-09-2012, 02:10 PM -
My first gear, a deadbeat escapement gear for my clock
By clockman in forum Woodworking Project ShowcaseReplies: 9Last Post: 30-01-2011, 11:39 PM
