    Hello: I tried changing cables, turning on/off, switching video cards ( I have 2 installed) and monitors without success. What do you suggest I do. Thank you
    Sent from my LGMS210 using Tapatalk
    Let's start with the basics you've omitted.
    When did you last have a display output from this PC?
    What has changed since then?
    Sir: I've not used the computer or monitor for over 2 years.
    Since then, I have not added nor modified any of the components.
    Replace the BIOS battery and see what happens, there is always the possibility of a board level failure.
    I'll try that. Thank you so much. I'll let you know. A lot of work ahead to get to the boa rd.
    I would try the monitor on another PC/source as well just to be sure that works.
    Before you change the bios battery, try simply resetting/clearing the bios first as the battery maybe ok and is usually the case.
    There should be a small pin jumper typically located in the same area as the battery, you sometimes need to remove this jumper or switch its configuration, I normally power the system on and off on both methods, if you look up the manual for the motherboard it should tell you how to do it for that board and the locations.
    Since the computer is old, I removed the battery already and I'm getting the replacement. I'll try using the monitor on a second cnc I have. I'll keep the option of resetting on hold. Thank you
    Gentlemen: I'm profoundly thankful. I followed your instructions and proceded to troubleshoot each component until I found that one of the two memory cards was apparently bad. Now I have video. Note: I removed all the cnc components I had attached to the case and built a separate box for them. Again, thank you!
    Great stuff, really pleased you got it sorted and thanks for letting us know!
    I think moving everything cnc related to a new box was a good idea, I was going to suggest this as space did look very limited in the PC case, though I have done this myself in the past and can understand why one would go down that route.
    What's next Ekfer ?
ID:	25455   Click image for larger version.
ID:	25456   Click image for larger version.
ID:	25457   Click image for larger version.
ID:	25458   Click image for larger version.
ID:	25459   Click image for larger version.
ID:	25460   Click image for larger version.
ID:	25461   Click image for larger version.
  1. FOR SALE: Microscribe MX, Dell Latitude 14 Rugged Laptop and Software
    By Mike14017 in forum Items For Sale
    Last Post: 04-11-2018, 05:39 AM
  2. FOR SALE: Heiz S-400 with Dell XP PC + numerous mill bits
    By hardygg in forum Items For Sale
    Last Post: 16-07-2017, 02:29 PM
  3. Replies: 4
    Last Post: 15-08-2016, 03:30 PM
  4. Dell monitor making a funny noise !
    By Lee Roberts in forum Monitors
    Last Post: 13-09-2013, 12:11 PM
  5. Why my company doesn't want to speed up the process?
    By membermy in forum General Discussion
    Last Post: 24-09-2012, 02:10 PM
