I would try the monitor on another PC/source as well just to be sure that works.
Before you change the bios battery, try simply resetting/clearing the bios first as the battery maybe ok and is usually the case.
There should be a small pin jumper typically located in the same area as the battery, you sometimes need to remove this jumper or switch its configuration, I normally power the system on and off on both methods, if you look up the manual for the motherboard it should tell you how to do it for that board and the locations.Lee
FOR SALE: Microscribe MX, Dell Latitude 14 Rugged Laptop and Software
By Mike14017 in forum Items For SaleReplies: 4Last Post: 04-11-2018, 05:39 AM -
FOR SALE: Heiz S-400 with Dell XP PC + numerous mill bits
By hardygg in forum Items For SaleReplies: 0Last Post: 16-07-2017, 02:29 PM -
Windows 7 ~ Microsoft relents on shorter Windows 7 support decree
By AndyGuid in forum Computer SoftwareReplies: 4Last Post: 15-08-2016, 03:30 PM -
Dell monitor making a funny noise !
By Lee Roberts in forum MonitorsReplies: 1Last Post: 13-09-2013, 12:11 PM -
Why my company doesn't want to speed up the process?
By membermy in forum General DiscussionReplies: 3Last Post: 24-09-2012, 02:10 PM
