    Quote Originally Posted by terry1956 View Post
    at the moment I am using fusion to make the g code and the circles are ok.
    What are you using when the code for circles isn't OK?
    Give a full example of a problem program?
    Chaz's Avatar
    Yep, share the code. It sounds like a mixup of settings (G91.1 sets Incremental mode).
    G90 & G91 Distance Mode
    Interpretation of Mac code can be in one of two distance modes: absolute or incremental.
    To go into absolute distance mode, program G90. In absolute distance mode, axis numbers (X, Y, Z, A, B, C) usually represent positions in terms of the currently active coordinate system. Any exceptions to that rule are described explicitly in this section describing G-codes.
    To go into incremental distance mode, program G91. In incremental distance mode, axis numbers (X, Y, Z, A, B, C) usually represent increments from the current values of the numbers.
    I and J numbers always represent increments, regardless of the distance mode setting. K numbers represent increments in all but one usage (the G87 boring cycle), where the meaning changes with distance mode.
    You also want to be sure you are not mixing MM and Inch.
  1. fault testing
    By Palletlad in forum General Computing
    Last Post: 09-02-2018, 05:51 PM
  2. Jun-Air Compressor Fault
    By jamesgates1000 in forum General Discussion
    Last Post: 02-12-2017, 07:59 PM
  3. fixed one fault, not i have a second
    By terry1956 in forum CAD & CAM Software
    Last Post: 17-02-2016, 08:34 PM
  4. Heidenhain DRO fault
    By Lancer in forum General Electronics
    Last Post: 29-06-2012, 09:57 AM
  5. ATX cycling fault?
    By mocha in forum Power Supplies
    Last Post: 07-12-2011, 02:08 PM
