    Hi
    I want to describe an idea that I had last days.
    As it is very possible to use epoxy level for my machine and I will use a small amount of epoxy ( that will finally go to thrash) for some tests. So I was thinking if it reasonable to make the tests using two aluminum rectangular tubes 80X20 as follows.
    We start with a 6 m long aluminum rectangular tube, cut into two pieces of 3m long each
Name:	straight edge 1.JPG
    We attach the two tubes with 2mm spacers( blue color)
Name:	straight edge spacers 2.JPG
ID:	17497Click image for larger version.
Name:	straight edge spacers.JPG
    At the edges we put two pieces of mdf as at the following pictures also with spacers between the mdf and aluminum profiles
    We put the spacers so that we can cut the epoxy after cure.
    Then we level the tubes, we fill with silicone the 2mm gap that the spacers will make and we pure epoxy.
Name:	straight edge mdf 1.JPG
ID:	17499Click image for larger version.
Name:	straight edge spacers epoxy.JPG
ID:	17501Click image for larger version.
Name:	straight edge spacers epoxy 2.JPG
    After the epoxy get hard, we remove the spacers and we use a hacksaw blade to cut the epoxy
    We now have (or we don’t have ????)two pieces of aluminum profile with a true surface.
Name:	single straight edge 2.JPG
ID:	17503Click image for larger version.
Name:	single straight edge.JPG
    MDF offsets are used to “absorb” the meniscus
    We will need nearly 0.5*6.6*300=990ml of epoxy ( for this length )
    1 X6m long aluminum rectangular tube
    Spacers
    Mdf strips
    Of course somebody could use shorter tubes, even one only tube with mdf stripes left and right or cut the tube (after epoxy cure) to different lengths.
    What is your opinion?
    Does it worth to try?
    I edit the post to make it more clear, ( after i read clives_s question that follows).
    The main purpose of this DIY is to make a straight edge with low cost, instead of buying one that at this length will be out of the question.
    The aluminum tubes that will be produced from the above process WONT be used as adjustable top beams where the rails will rest
    The creative adult, is the child who survived
  1. BUILD LOG: Aluminum profile and alu plate 1500mm x 600mm x 150mm working area, first cnc.
    By pierantoine in forum DIY Router Build Logs
    Last Post: 01-04-2017, 11:33 PM
  2. Low profile, compact work-holding solutions. Advice sought.
    By Wal in forum Tool & Tooling Technology
    Last Post: 26-08-2016, 10:45 PM
  3. Straight sections of box steel
    By gavztheouch in forum Metalwork Discussion
    Last Post: 03-01-2012, 02:37 PM
  4. can't cut straight or even drill straight, so need help
    By deannos in forum Machine Discussion
    Last Post: 02-10-2011, 05:35 PM
  5. Electronic edge finder: how do they work?
    By irving2008 in forum Probing, Digitizing & Scaning
    Last Post: 29-08-2009, 10:25 PM
