22-10-2019 #5
I cut phenolic a lot. I would like to see you cutting phenolic at 30k rpm
. One can not evacuate chips at that speed and relative to the size of the bit depth and you will glue and break your cutters.
I cut phenolic at wood RPM and 1/3 the feed for wood, for perfect finish , especially when going deep. Now i can much speed that up HSM and blowing air in the cut, but the only reason i see doing that is serious production. Otherwise one will have to stay there and be like vigilante so the bit does not break. I prefer drinking beer while my robot does the job.
Like Dean said 2kw spindle will do that perfectly. You should worry finding and paying for ultrasharp bits in that size. Cause chinese will not do. I use Kyocera.
Chinese 300W DC spindle - is the spindle shaft grounded?
By HankMcSpank in forum Spindles & Drive MotorsReplies: 44Last Post: 26-11-2016, 07:25 PM -
Recommend me an ATC Spindle
By andy_con in forum Milling Machines, Builds & ConversionsReplies: 14Last Post: 26-07-2016, 10:40 PM -
1.5Kw Chinese Spindle help
By Hasanain in forum Generic Chinese SpindlesReplies: 3Last Post: 26-05-2016, 10:38 AM -
WANTED: Spindle holder for 1.5kw Chinese spindle.
By jcb121 in forum Items WantedReplies: 19Last Post: 14-10-2011, 02:07 PM -
Can anyone recommend a spindle for milling PCB and cast acrylic?
By HankMcSpank in forum Spindles & Drive MotorsReplies: 10Last Post: 11-10-2011, 08:54 PM
