Hi. I'll make a video tomorrow to upload on Youtube. Should be better I think. Thanks for your reply!
19-02-2019 #2
no probs. i'll check back tomorrow
20-02-2019 #3
Hi. Here is a Youtube link with the short video showing how I can't save the G54 position. Sorry for the annoying music on the background :) I've tried to save it under MDA and Automatic and Determine WO but still the same. Thank you in advance!
https://youtu.be/0m7qHg7FRrALast edited by Maxiscnc; 20-02-2019 at 03:33 PM.
20-02-2019 #4
so I've had a look at your video and I am sure that the work offset is correct as the two figures where the machine moves to are the same distance apart as the difference in the work offsets that you changed.
I think the problem is in the base setting which is where the offsets come from. could you show a pic of where your base value is set. on our machines the base x and y value is set to zero.
20-02-2019 #5
Thanks John. I’ll post some pictures tomorrow. I’ve changed the base offset a while ago and now I'm not sure how to reset it to the system default. Many thanks for your reply! Regards, Angel
21-02-2019 #6
Hi John. For some reason I can’t upload pictures at the moment. There is error message when trying to upload. Anyway, I have check many stuff on this control today and I can make my own zero offset ( G54 ... G57 .. ) but only way to do it is manual. I have to calculate the distance betwin the base zero position and material. On my Base Work Offset I have X 118 / Y -14 / Z 88. I still can’t do it in the automatic way :(
21-02-2019 #7
hi max. there is your problem with your base work offset. x and y should be zero. if you look at your video that you took, your g54 offset that you set was approx. x216.xxx and when the machine moved it moved to x334.xxx which is 118mm more. once you set your base to x0 y0 your work offsets will move to the correct place. this base figure is where all the other offsets come from, so also beware of your z offset being 88. My z offset is set to zero aswell so all my z offsets in g54-7 are a positive figure above the bed. I hope this has helped you.
PC MILL55 with WINNC incremental jog pc keyboard control
By chaplipa in forum Emco Milling MachinesReplies: 1Last Post: 02-07-2016, 09:24 PM -
Eding CPU5A4E controller and Siemens G110 VFD.
By calgone in forum EdingCNC (CPU5, CPU5A)Replies: 4Last Post: 06-02-2015, 11:31 PM -
Mach4 in production run G52 offset with Sub
By Lee Roberts in forum Artsoft Mach (3 & 4)Replies: 8Last Post: 25-08-2014, 11:53 PM -
DXF with tool offset
By Cube3 in forum CAD & CAM SoftwareReplies: 4Last Post: 25-03-2014, 10:54 PM -
Poorly siemens inverter, wont switch on.
By jonisonvespa in forum Spindles & Drive MotorsReplies: 7Last Post: 06-12-2012, 04:45 PM
