18-02-2019 #1
Hi all,
I'm very new in the industrial CNC so I have a problem which probably will sound funny for more of you but I've spend lots of time to find how to setup zero offset on WinNC Sinumerik 810D/840D. This is a Emco PC Mill 155. I'm following step by step the manual but G54 zero is never where I'm tried to save it. I have setup properly the Base offset and in MDA G0 X0 Y0 Z0 everything is fine and machine going right there but if I put G54 machine going on the same wrong place in the table and if I tried to put G54 X0 Y0 there is error message ' X axis is out of software limit' Seems like my offset is not saved. I miss up something but still don't know what :( Could you please give me step-by-step procedure how to find the material zero point. Any help is very welcome!
Thank you in advance!!!
PC MILL55 with WINNC incremental jog pc keyboard control
By chaplipa in forum Emco Milling MachinesReplies: 1Last Post: 02-07-2016, 09:24 PM -
Eding CPU5A4E controller and Siemens G110 VFD.
By calgone in forum EdingCNC (CPU5, CPU5A)Replies: 4Last Post: 06-02-2015, 11:31 PM -
Mach4 in production run G52 offset with Sub
By Lee Roberts in forum Artsoft Mach (3 & 4)Replies: 8Last Post: 25-08-2014, 11:53 PM -
DXF with tool offset
By Cube3 in forum CAD & CAM SoftwareReplies: 4Last Post: 25-03-2014, 10:54 PM -
Poorly siemens inverter, wont switch on.
By jonisonvespa in forum Spindles & Drive MotorsReplies: 7Last Post: 06-12-2012, 04:45 PM
