Where DIY is concerned, I'm a bit of a Jack (or should that be Jill?) of all trades, but mistress of few (if any!). I have been establishing a woodworking workshop which, for a hobbyist, is reasonably well equipped (table saw / spindle moulder combo, planer / thicknesser, band saw etc.). For some time I have thought that a cnc router would be useful to add. In truth, I probably can't afford it or justify it, but hey, since when did such details impede the female of the species when in need of a little retail therapy? However, it does mean that I should seriously consider the DIY build route.
My interest is centred on a router for woodworking. Ideally, I'd like to leap in the deep end and go for a full 4' by 8' working area. In order to be able to undertake reasonably heavy work in either soft- or hard-wood, I imagine I should be thinking in terms of a router spindle of around 2kW. What workpiece hold down system is appropriate? Is a vacuum system at all practical for a home builder? What are the best sources of equipment in the UK? (I've come across Marchant Dice so far.) I've started doing a bit of research online, but still have a lot to learn.
As I'm not really into metalwork, I'm thinking of construction primarily from wood / MDF. My existing wookshop set up should enable me to undertake such construction with sufficient accuracy. I've found various links to websites offering plans for specific designs and / or showing videos of DIY build projects. However, I'm still trying to find a good basic "idiots' guide" on the subject that would help me to identify a suitable construction and the best / most suitable components to specify.
Any pointers are most welcome.
Julie
29-09-2009 #2
Excellent, another Sussexite and one who thinks big
The cheapest way to track it will be round, supported rail. Driving it will be fun, as will keeping the 4' gantry running square. Stepper motors are cheap but there is always a trade off between accuracy and speed when you go large size. Servo motors could be the way to go. You don't want to wait 5 minutes while it goes end to end. You don't want to rely on fine microstepping to do fine detail.
Maybe allow for a vacuum bed in the design but start by using a crummy adhesive such as the humble Pritt stick while you get a feel for the problem.
Do you have a specific item for cutting in mind? Suggest you post preliminary design sketches here and see if you get a big thumbs up or howls of anguish :whistling:
30-09-2009 #3
Hi Robin,
Thanks for the quick reply. I guess my continuing to set ambitions above abilities is an on-going victory for hope over experience!
I'm interested in what you say about servo motors, rather than steppers. If you servos at all, I guess it's best to use them on all axes to have common control logic?
I appreciate your point about a 4ft gantry. I had seen the Blacktoe 4 x 8 project on buildyourcnc.com, which uses MDF for construction. However, I did note that the gantry structure was made pretty beefy. As for keeping it running square, at that size I'm guessing you need to provide a motor on each side to drive the x-axis?
Still a lot to learn.
Julie
30-09-2009 #4
Welcome to the forum Julie, promise I won't swear (too much)!
I have been considering designing a larger machine also and have been lurking around youtube and various 'other' DIY CNC sites for idea's before I put mouse to screen.
Found this site on my travels - http://www.automatedwoodworks.com/
I think this guy has done a half decent job, take a look at his gallery and his youtube video's. He is using steppers which are a much cheaper option than servo's and he is getting decent rapid speeds.
Like other people have said, with steppers its a trade off between speed and accuracy, on my current machine I am using 16 x 5 ballscrews which are directly driven off of a 23 size 3.1Nm stepper, with a 5A driver I can run comfortably at 5m/min and I have had it up to 7m/min. I am running at 1/4 step so this give 800 steps per 5mm, this = 0.0063mm which is fairly accurate!
I am thinking of using the same steppers and drivers for a larger machine but gearing them 2:1, this should double the rapid speeds and half the accuracy but still give me 0.0126mm per micro step. Pretty sure that the 23 steppers will be fine but may consider going up a size to be on the safe side.
Will probably belt drive it and just use one stepper for the long X axis with a shaft to link the drive belts on either side to avoid any crabbing.
Just my two penneth worth!
30-09-2009 #5
Hi Julie
That's to be avoided like the plague :nope:
First you have to decide what kind of accuracy you want to achieve for the cut. Think resolution. The motor moves the table by one increment. A small increment improves the accuracy of the cut. A large increment improves your top speed which is handy when you want to move 8' ASAP.
When you have an accuracy figure in mind you can decide how to drive it. Screws, rack and pinion, belting? The lower the accuracy the cheaper it becomes. It's all trade offs, what are you trying to achieve? Are we talking mass production where speed is king? Are we talking bespoke and it doesn't really matter if it takes 2 minutes to move end to end at a lowly 2 cm/second?
Robin
30-09-2009 #6Visit Us: www.automationshop.co.uk
30-09-2009 #7
Hi all
Just an idea regarding the x axis 2 motor thing, if i were doing it i would put a lead screw/ballscrew on each side conected by a timing belt and pulleys, with a double pulley on one side then drive the second pulley from the motor, also this gives you some flexibility with pulley sizes, small motor pulley for accuraccy large motor pulley for speed. Shoud also work with rack and pinion systems with a long drive shaft.
Thats the way i would go if i were building it from scratch, that way its just the one motor driving both sides of the axis, and a swap out pulley set up with the progam,
Thanks for listening
Still a newbie so dont take me too seriously..
29-09-2009 #8
Hi Julie,
Welcome to the forum.
Only advice I can give is:
Know what you want to make beforehand and size your machine accordingly. It's pointless having an 8X4 router and then having it only making 18" long house signs.
CNC is really, REALLY good at multi-run jobs, but not for one-offs unless you can price it right. It ISN'T just another tool like a drill or a planer, it is a manufacturing system that can do the jobs of all your machinery in you workshop but I bet 90% of the time you will use the drill or the planer or whatever simply because it is easier and quicker to do than writing the program or generating the CAD/CAM. WHen I first built mine and I wanted to say cut a 20mm groove across a sheet for a shelf to fit into, I would clamp it down and zero the machine, then type in a move to the appropriate distance up the sheet, lower the Z to the required depth and then simply zip the cnc across the sheet, job done. I don't do that anymore, I just clamp a straight edge across the sheet and run my triton router across it by hand like I used to, quicker and easier.
If you want to get into 8x4 size machines and cutting the likes of oak etc. think of getting into welding classes and build it from steel with supported rail on all axes, rack and pinion on the 8' axis and ballscrew on the other two. IMHO an 8x4 from MDF or baltic birch can't hold a candle to a steel or aluminium framed machine for rigidity, Irving will be able to fill you in on the deflection of wood vs steel. If you are thinking of doing this professionally, i.e. to earn a living from, then you really need to be building in longevity and accuracy IMO only a steel framed design will give you that on the scale of machine you are looking at.
You are looking at splashing £2,500+ to get a half decent machine up and running, 8x4 really is getting into commercial territory size-wise and it might be cheaper or more sensible to look at a second hand commercial machine. If you want to build one for the experience, knock yourself out, that's why I built mine and I can honestly say it's the best thing I've ever made and the most fascinating hobby I've ever had.
I don't want you to think I'm trying to put you off but do yourself a favour and decide in the first place what you want to actually DO with the machine and stick to it!
All the above my own humble opinion as always but good luck whatever you do and don't forget if you start to build one, we want to see pictures!
JeffNothing is foolproof......to a sufficiently talented fool!
30-09-2009 #9
Hi Jeff,
Thanks for the reply. I'm not put off by your words of warning and do appreciate all advice and points of view.
I do have some clear ideas on what I want to do. My most immediate requirement is to do engraving on a large number of wooden panels. They will not be very wide, but will be of varying length, with many of them being in the 2 to 2.5 m range. My current solution (which I have prototyped) has been to make up a wooden jig then use a bearing guided cutter in my hand router. It works, but I would expect to able to get better accuracy and finish from a cnc tool. Beyond that, I have other ideas, but nothing so specific yet. However, I think I'm sufficiently clear on my needs and ambitions to decide that if I do this at all, I should go for the size I've suggested. Equally, other functionality that might be nice to have, such as additional axes, are not high on my priority list at present. In summary, yes I do think I''ve got a suuficient handle on what my needs are.
I certainly wouldn't dispute your point that a cnc router would never be the best option for all tasks. I have many other machines and hand tools in my workshop that will continue to earn their keep.
I think welding is a skill too far for me at this stage. However, since my original post yesterday, I've noted one or two websites advertising ranges of extruded aluminium profiles. This has started me thinking. I should be able to handle that, provided I can lock everything together by mechanical means (i.e. brackets or other fixings).
I'm interested in your suggestion to go rack and pinion on the long axis and ballscrew on the others. Is this because rack and pinion is better over such lengths or is on the basis of cost for a ballscrew system with sufficient rigidity at that length? (I'm not doubting your advice, just keen to understand the rationale behind it.)
I was wondering whether anyone was going to come back on me with regard to my idea that the router spindle should be of the order of 2 kW. I note that commercial machines are at this rating or, indeed, much higher. The only DIY offerings I've seen so far though are the Kress models that only go up to about 1kW. I've noticed that large commercial machines often talk about water cooling. I wouldn't want to go to that complexity. I could go 3-phase (off an RPC that I've already installed to drive my saw / spindle moulder) but would probably rather stick with single phase.
I have had a long term search set up on ebay for cnc routers, and while they certainly come up regularly, anything that might fill my wishes (adequate size, not too ancient) still goes for more money than I could contemplate. For example, there's currently a Pacer Cadet on offer. It has only a 1220 x 700 mm bed, albeit with computer and vacuum pump thrown in, but the seller is seeking around £6k.
As you can see, I really would benefit from a good, comprehensive idiots guide if one exists.
Julie
30-09-2009 #10
The problem with ballscrew is that the longer you need, the thicker it has to be, or the slower you need to drive it (otherwise it whips).
Rack and pinion doesn't have problems with length (and if you need it longer, you can "just" bolt on another length).
There are currently 7 users browsing this thread. (0 members and 7 guests)
