Thread: Game on!
Page 8 of 8 FirstFirst ... 678
  1. #71
    Nice one! Looks great!
    Don't suppose you'd knock off another insert for those of us without a lathe handy?
    (Technically the lathe is just a few hundred miles away covered in a mountain of crap, but I've never used it, and plan to eventually start gently...)
    I'll have a go - means I'll have to measure that one though! Might be a week or two as v.busy at the mo.
  2. The Following User Says Thank You to Voicecoil For This Useful Post:
  3. #72
    This was borne out of a cockup, but might be of interest to someone else. I'd originally intended to have some bellows covering the rails and ballscrew on the gantry (my X axis), but when I came to fit them I found I'd made an error in the drawing and there wasn't quite enough clearance at the bottom so they fouled the carriage plates. It won't be a problem in the long run as I was intending to remake the carriage plates anyway now that I have proper milling capacity, but that's been put back a bit due to work pressure and supply problems with aluminium stock due to the virus. Observing that the X axis ballscrew was frequently getting sprinkled with chips, I thought some other form of protection was in order. I rang a few of the machine guarding people but everything they had on offer was too big and/or too expensive. After a bit of thought and fiddling, it looked like some kind of blind arrangement would be the best option given the limited space. I fiddled around with springs out of an old window blind, but the force was far from constant and it was a pain to put together without getting custom springs made. Then the thought struck me that a DC motor supplied with a constant current gave constant torque..... So I came up with these:
    Not a 100% perfect solution, but they seem to be keeping the ballscrew clean, and apart from a couple of £10 motors off the Bay of fleas, were made from scrap bits lying around. I've set them up so they're switched on by the X axis enable signal, though the motors don't even get warm if on continuously.
  4. #73
    that picture really got me confussed. I looked at it and thought why as he got green caps on the ends of those rails... then i realised the green was the bearing caps...
  5. #74
    I did something similar on my mill Z axis. Took some car window blinds apart, stuck some 0.5mm nitrile sheet on the roller and it actually works.
    The things you have to do
  1. New to this game and need link to Chai at lineramotionbearings Ebay page
    By worksengineer in forum Marketplace Discussion
    Last Post: 30-06-2014, 06:37 PM
  2. trying to improve my board game
    By cubikoman in forum General Discussion
    Last Post: 12-05-2012, 06:57 AM
  3. NEW MEMBER: I'm new at this game.
    By rwery in forum New Member Introductions
    Last Post: 01-06-2009, 01:48 PM
