Thread: Game on!
31-01-2020 #27
In that case, you are bending the ball-screws because they are fixed to the top plate while the bottoms are fixed to the upright plates which your moving causing a twist on the screw. Also, the ball-screws must stay aligned perfectly parallel to the rails which they cannot do this way because you have them fixed to the top plate.
This design fails the golden rule of DIY to me.? Which is build-in Adjustment, adjustment, adjustment and bit more adjustment just for good measure?
Pointless if they cause vibrations through the spindle, which they will do compared to if they were fixed directly to backplate like on conventional design. You could also use a similar supporting strip on the rear plate if felt it was needed on conventional design but without causing vibrations.
New to this game and need link to Chai at lineramotionbearings Ebay page
By worksengineer in forum Marketplace DiscussionReplies: 6Last Post: 30-06-2014, 06:37 PM -
trying to improve my board game
By cubikoman in forum General DiscussionReplies: 28Last Post: 12-05-2012, 06:57 AM -
NEW MEMBER: I'm new at this game.
By rwery in forum New Member IntroductionsReplies: 1Last Post: 01-06-2009, 01:48 PM
