Thread: Game on!
    Marking out the bed plate:
    I need a bigger surface plate!!!
    As a pen-pusher, I'm guessing that your method is a very accurate way of manually Marking Out Using a Surface Plate and Height Gauge ?
  3. The Following User Says Thank You to AndyGuid For This Useful Post:
    Yes, I bought the height gauge and optical centre punch for this project and I've been suprised at how accurately you can do things - I reckon on smaller pieces the max error isn't much more than +/- 0.1mm and maybe twice that on longer bits: quite a novelty not to have to file out holes to get things to line up! Mind you, when you think about it people were making accurate stuff 60 to 70 years ago before CNC was even thought of, so it had to be possible.
  5. The Following User Says Thank You to Voicecoil For This Useful Post:
  6. #4
    Yesterday and today I've been assembling the various parts of the bed/Y-axis to check fit before doing a bit of anodising.
    All went reasonably well apart from a couple of screw heads (that need to be moved) fouling stepper motor bodies and a small CAD error on the carriage side plates that I'd transferred really precisely into metal - time to get the file out!
  7. #5
    Looking Good
  8. The Following User Says Thank You to mekanik For This Useful Post:
  9. #6
    Having found it very difficult (or very expensive) to get anything done on a reasonable timescale by the local anodisers, in desperation I thought I'd have a go myself. £50 worth of chems and some plant troughs later I managed to get the gantry box done this evening, took a bit of fiddling with the process but not too shabby in the end.
  10. #7
    looking good
  11. #8
    With all the beams now anodised I thought it was time to indulge in a bit of damping, as handling the box sections in particular showed that they were ringing a lot at mid-audio frequencies (which match up nicely with the stimulation given by typical spindle speed/cutter flutes). I thought I'd try my old fave Tecsound, but wasn't overly confident of it working as I've never used it on anything thicker than 2mm thick metal sheet before, and the box sections I've used for the side beams and gantry are 7 & 10mm thick wall. However in reality it seems to work pretty well, hanging an untreated section up on a piece of wire and giving a gentle tap with a hammer gives something not unlike a tubular bell, whereas a damped section is just a bit of a thunk. Here's some sound files from the tapping to illustrate the difference
    Side beam undamped.mp3
    Side beam damped.mp3
    Looking at the decay time in an audio editor, the damping has been increased by something like 6X - a useful improvement I think - now to do some of the other parts!
    Attached Files Attached Files
  12. The Following User Says Thank You to Voicecoil For This Useful Post:
  13. #9
    Thought I'd better check fit on the Z-axis before assembling the gantry as the X carriage is integral to it: all fitted suprisingly well once I'd clocked that the Z slide extrusion was supplied under-width and was causing the assembly to sieze at the end of travel
  1. New to this game and need link to Chai at lineramotionbearings Ebay page
    By worksengineer in forum Marketplace Discussion
    Last Post: 30-06-2014, 06:37 PM
  2. trying to improve my board game
    By cubikoman in forum General Discussion
    Last Post: 12-05-2012, 06:57 AM
  3. NEW MEMBER: I'm new at this game.
    By rwery in forum New Member Introductions
    Last Post: 01-06-2009, 01:48 PM
