    On my mill I used a pair of ordinary angular contact bearings and sprung them using the end of an old square section air rifle spring crushed close to solid.
    It's all rolling contact so it spins freely on the handle, the spring compensates for temperature change and it doesn't move one jot unless I make a horrible mistake.
    If your frame can take the strain, one bearing at either end is definately best because it keeps the whole thing in tension. I used two at one end but plan to rework it with die springs when I get the time because it works so well and I have become anal about the .003" backlash. I'm thinking 2 ball nuts and another spring.
    The cheapest place I found for the bearings was VXB Bearings on eBay, cheapest despite the trans-pond shipping.
    Any chance you have a pic of that setup for us to see ?
    Quote Originally Posted by CNCUK View Post
    It's rather enclosed, no seals on the bearings, had to bury it a bit.
    I would take a pic but I just moved the workshop out of the garage up on to the industrial estate :D
    Ok Robin some other time maybe, i think we all know what it is like to have a work shop with space!
    Cheers Mate.
    I had plenty of room but the big benefit is not worrrying about her indoors moaning about metal cuttings walked in to the house. I forgot to tell her that swarf is death to carpets so I was actually getting away with it :D
    Also I can now play at CNC plasma cutting without sooting up her car (double garage) and I have bought this book on how to melt cast iron by burning old engine oil. Not the sort of thing I want to do under he watchful eye in case there's a spillage.
    Quote Originally Posted by Kip View Post
    Sounds like fun! I'm intending to build a cupola over the winter using some Babington burners....I have the balls already! Babington burner
    Hi kip, what is a cupola ?
  1. Hobbymat BFE65 Leadscrew info, fitting anti backlash nuts
    By manofgresley in forum Milling Machines, Builds & Conversions
    Last Post: 09-05-2014, 04:35 PM
  2. Ballscrews v. acme screws
    By russell in forum Lead Screws, Nuts & Supports
    Last Post: 25-10-2011, 07:46 PM
  3. FOR SALE: round rails and acme screws
    By johngoodrich in forum Items For Sale
    Last Post: 15-08-2011, 05:41 PM
  4. Source of multi-start ACME or Metric Trapezoidal Leadscrew and Anti Backlash Nuts
    Last Post: 16-03-2010, 10:11 PM
  5. Commercial Sieg X1 anti backlash nuts ?
    By cweeks in forum Milling Machines, Builds & Conversions
    Last Post: 28-05-2009, 06:41 PM
