Thread: Re water cooled spindle
05-07-2019 #1
Hi I'm building a all steel cnc router and looking at spindle motors, I see most of you have the 2.2 kW water cooled spindle.
I see now that there is a 3.0 kW water cooled spindle available on eBay for a little bit more money ,
I want to cut aluminium with my machine is it worth upgrading to the 3.0 kW
Spindle,
Thanks Paul
05-07-2019 #2
For cutting aluminum - i don't think so, and i can prove it with some calculations of feed and speed if you need. For example on a sturdy machine i can take cuts with 6mm flute 3-6mm deep with 0.8kw spindle
But if you do that every day- yes, the 3kw spindle has bigger bearings. And will have longer life.
Where 3kw is more than 2.2 KW is cutting wood deep or using big cutters. making channels in doors, 3d work, etc.
Anyway, in all that cases you machine has to be extremely sturdy so to be able to make difference. 99% of the time the fixture or the way you fix workpiece is much more important than the KW of the spindle.
PS. on a production machine always the bigger is the better.
Hope that helps!Last edited by Boyan Silyavski; 05-07-2019 at 05:43 PM.
05-07-2019 #3
Thanks Boyan
The main reason for asking was it's about £60.00 more as I need to buy one anyway.
So thought I would ask the question.
Cheers Paul
Sent from my SM-G900F using Tapatalk
Water cooled vs Air cooled spindle for wood
By Bucks in forum Machine DiscussionReplies: 5Last Post: 06-02-2017, 01:58 PM -
Where to buy 2.2Kw Water cooled spindle + VFD
By RocketBoy in forum Marketplace DiscussionReplies: 3Last Post: 01-08-2016, 12:38 PM -
Water cooled / air cooled 2.2kw spindle
By suesi34e in forum Generic Chinese SpindlesReplies: 15Last Post: 25-02-2015, 04:57 PM -
Do you need to water cool erhm a water cooled spindle?!!
By HankMcSpank in forum Generic Chinese SpindlesReplies: 18Last Post: 02-10-2013, 09:59 PM -
Cooling a water cooled spindle, without pipes everywhere & huge water tanks/buckets!
By HankMcSpank in forum Generic Chinese SpindlesReplies: 17Last Post: 18-09-2013, 06:32 AM
