25-02-2019 #1
Hi All,
I have just bought a 2.2kW Chinese spindle and a Huanyang 2.2kW inverter:
This spindle:
https://www.ebay.de/itm/EU-2-2KW-220...72.m2749.l2649
and this inverter:
https://www.ebay.de/itm/At-DE-2-2KW-...iV7H:rk:1:pf:0
I bought this combination because the motor is a TIR < 10um, and I was of the impression that Huanyang inverters are the better of the cheaper inverters (which is what I may currently afford).
As it is I am currently "running in" the motor and VFD and here I notice that there are some vibrations in the motor ... I have placed the motor on a bit of flexible foam and although the vibrations are not "large" they are noticable, even if the spindle motor is free-running, i.e. no end mills or anything attached. I have run the motor from 3000 rpm to ~ 10000 rpm by now.
It also seems to me that the vibrations may at least in part be electronically generated - by this I mean that it seems that it could be some kind of electronic "imprecision" of the HY inverter that causes the spindle to vibrate. I say this because at low frequencies it was quite noticeable that the inverter caused "fluttery" spindle motor rotation and this appeared to continue when the rpm was increased ...
Does this sound far off or might it be possible? And if it is possible might one of you know if there is a parameter(s) in the HY inverter that can be set up to amend for this?
Another option of course also is that I am noticing something which is quite normal for a spindle, however, I just would have expected a spindle with a TIR < 10um to run very smoothly ...
I'd appreciate any insights from people here
Cheers,
JesperLast edited by evalon; 25-02-2019 at 04:08 PM.
Seek advice on which small quality router to buy/build ...
By evalon in forum Gantry/Router Machines & BuildingReplies: 12Last Post: 06-02-2017, 08:06 AM -
Chinese 300W DC spindle - is the spindle shaft grounded?
By HankMcSpank in forum Spindles & Drive MotorsReplies: 44Last Post: 26-11-2016, 07:25 PM -
Interesting Papers on heavy duty design, vibrations, composites and column design
By D.C. in forum Gantry/Router Machines & BuildingReplies: 15Last Post: 25-06-2016, 10:13 PM -
Water cooled chinese spindle collets, Advice from owners please
By craigrobbo in forum Generic Chinese SpindlesReplies: 15Last Post: 11-05-2012, 12:08 PM -
WANTED: Spindle holder for 1.5kw Chinese spindle.
By jcb121 in forum Items WantedReplies: 19Last Post: 14-10-2011, 02:07 PM
