  1. #20
    You say:-
    "PWM to wire 3", and separately, "although the PWM output voltage does alter accordingly".
    What have you wired to the speed controller pin 3?, the PWM ("...output voltage does alter...") or the P1 pin?
    EDIT: Sorry, I appreciate I seem to be repeating myself, without explanation:-
    The PWM ("Pulse Width Modulation") output from the PC is typically Pin1 of the parallel port - and you've confirmed this is how it's assigned in Mach. Okay so far. This pin/signal is a digital signal, alternative between On ("Mark") and Off ("Space"). The ratio of Mark/Space defines the PWM value, essentially a per-unit measure from 0 to 1 for Off to Full-speed. Increase the Mark ratio vs Space and you denote a speed increase.
    Pin 1 of the BOB is connected (using the schematic from John), to two inputs on one of the octal transceivers (74x245) - inputs B2 & B3. The "DIR" direction pin on that chip is set to transfer from port B to port A. So the PWM input appears on A2 & A3. A3 is connected to the connector P1 on the BOB, and as such presents a buffered copy of the digital PWM (Mark/Space signalling) from the PC. It is this that needs to be connected to the speed controller. The other port, A2 is connected to an opto-isolator, through to the op-amp (half of LM358) which is configured as an integrator - it converts the Mark/Space ratio to an analogue voltage. This would be used for an analogue input to a speed controller (but NOT a digital PWM input).
    It's for this reason that I'm asking you to confirm which PWM signal you have connected to the speed controller - because you refer to the PWM signal in an analogue sense.
    Unfortunately much of what you are telling me is going over my head!
    This is how its currently wired:
    Does the fact the altering of the pwm voltage through mach3 commands makes no difference to the output from the controller board to the motor indicate a problem with the board itself?
  2. The Following User Says Thank You to Tel 27 For This Useful Post:
  1. NEE AMC-E schematic or suggested alternative control boards
    By DaveBee in forum General Electronics
    Last Post: 05-03-2019, 04:31 PM
  2. Control Schematic Advice
    By GTJim in forum General Electronics
    Last Post: 05-10-2015, 11:48 AM
  3. Limit switches PCB schematic verification.
    By cncnoob in forum General Electronics
    Last Post: 25-02-2013, 09:28 PM
  4. Schematic anyone?
    By boldford in forum General Electronics
    Last Post: 28-08-2012, 10:09 AM
  5. Schematic Symbol Reference
    Last Post: 23-01-2008, 03:23 PM
