Thanks for the replies gents - good to have people at least trying to help me despite my limited electrical understanding!
Havent had much time to look at it for a couple of days, but having read the reply about measuring the output voltage with the meter set on ac, it does indeed read 0.2v ac when programmed s1000 via mach 3 (assume that means its a result of pwm "wave"?)
As you can see pwm is activated to output on p1
05-03-2019 #2
Be bold :) Just wire it up. There's not much that you can do via ribbon #3(+) / #4(-) to cock it up. #3 to P1, #4 to gnd.
09-03-2019 #3
Well, tried that, (pwm to wire 3) the spindle fires up and goes to 3500rpm (when s250 m4 is mdi input on mach3)
Altering the s value makes no difference to the spindle rpm, (i.e. s25 gives the same 3500rpm!) although the pwm output voltage does alter accordingly...
any more ideas?
09-03-2019 #4
You say:-
"PWM to wire 3", and separately, "although the PWM output voltage does alter accordingly".
What have you wired to the speed controller pin 3?, the PWM ("...output voltage does alter...") or the P1 pin?
EDIT: Sorry, I appreciate I seem to be repeating myself, without explanation:-
The PWM ("Pulse Width Modulation") output from the PC is typically Pin1 of the parallel port - and you've confirmed this is how it's assigned in Mach. Okay so far. This pin/signal is a digital signal, alternative between On ("Mark") and Off ("Space"). The ratio of Mark/Space defines the PWM value, essentially a per-unit measure from 0 to 1 for Off to Full-speed. Increase the Mark ratio vs Space and you denote a speed increase.
Pin 1 of the BOB is connected (using the schematic from John), to two inputs on one of the octal transceivers (74x245) - inputs B2 & B3. The "DIR" direction pin on that chip is set to transfer from port B to port A. So the PWM input appears on A2 & A3. A3 is connected to the connector P1 on the BOB, and as such presents a buffered copy of the digital PWM (Mark/Space signalling) from the PC. It is this that needs to be connected to the speed controller. The other port, A2 is connected to an opto-isolator, through to the op-amp (half of LM358) which is configured as an integrator - it converts the Mark/Space ratio to an analogue voltage. This would be used for an analogue input to a speed controller (but NOT a digital PWM input).
It's for this reason that I'm asking you to confirm which PWM signal you have connected to the speed controller - because you refer to the PWM signal in an analogue sense.Last edited by Doddy; 09-03-2019 at 07:59 PM.
11-03-2019 #5
The Following User Says Thank You to Tel 27 For This Useful Post:
12-03-2019 #6
No. In fact it's exactly as I'd expect from the information that you've supplied to date. If you was to set the speed to 10% of max (assuming you've calibrated it) then I'd expect the spindle to be OFF. And above about 25% I'd expect it to be full-on. This is simply the (wrong) application of the analogue output from the BOB to the opto-isolator input to the speed controller, which instead expects a PWM input.
Simply. Connect the BOB output pin P1 to ribbon Pin 3. Connect the Ground used for the BOB to ribbon Pin 4. There is no need for any of the resistors.
Rough-arsed sketch - the PC output pin-1 is a digital PWM output. The BOB routes this to two different outputs - the BOB "P1", which is a facsimile of the PC output - and is the signal you need. There's also an on-board (the BOB) integrator that converts the PWM to the analogue output, that you don't need. Your speed controller takes a digital PWM input and uses this either to generate the analogue drive to the onboard speed controller, or simply uses this to drive the onboard MOSFET to drive the spindle. Regardless, the important bit is that the speed controller around the pin 3/4 terminals is designed around having a Digital PWM input, and NOT an analogue input (which, confusingly, is derived from a PWM source)
The Following User Says Thank You to Doddy For This Useful Post:
12-03-2019 #7
NEE AMC-E schematic or suggested alternative control boards
By DaveBee in forum General ElectronicsReplies: 2Last Post: 05-03-2019, 04:31 PM -
Control Schematic Advice
By GTJim in forum General ElectronicsReplies: 49Last Post: 05-10-2015, 11:48 AM -
Limit switches PCB schematic verification.
By cncnoob in forum General ElectronicsReplies: 18Last Post: 25-02-2013, 09:28 PM -
Schematic anyone?
By boldford in forum General ElectronicsReplies: 3Last Post: 28-08-2012, 10:09 AM -
Schematic Symbol Reference
By Lee Roberts in forum General ElectronicsReplies: 1Last Post: 23-01-2008, 03:23 PM
