Thread: Z stepper motor problem
06-03-2019 #2
Hi Terry, This sounds exactly the same as the problem I had. Mine turned out to be a broken cable in the Z. It was making contact every now and then. Have you test driven the Z axis from another socket ?
These problems can be a bugger to find. My Z axis had a preponderance to go downwards and the job it happened first on was ruined and the cutter went on to gouge the bed afore I could get to the 'Oh Shite' button.
In the end I made a join with a connector that was fixed to the Z axis so there was no movement of the wires coming out of the stepper. My 3D printer has gone through 2 stepper cables on the only axis where the cable moves significantly. The breaks were internal in the wires and first time difficult to find. Second time I just replaced the cable at the first sign of failure.
Best of luck with your fault finding.
Cheers,
RobLast edited by cropwell; 06-03-2019 at 05:40 AM.
Stepper problem
By eurikain in forum Stepper & Servo MotorsReplies: 32Last Post: 19-12-2015, 03:25 PM -
Removing stepper motor problem from sherline mill
By Neeps in forum Sherline MillsReplies: 1Last Post: 12-04-2015, 12:09 AM -
How do I wire a stepper driver to a stepper motor?
By swood1 in forum Stepper & Servo MotorsReplies: 7Last Post: 21-09-2014, 05:40 PM -
Stepper Motor Driver - cheap similar to ArcEuro 4.2A Bi-Polar Stepper Motor Driver
By craynerd in forum Motor Drivers & ControllersReplies: 1Last Post: 16-03-2014, 07:29 PM -
Stepper motors - problem
By dudz in forum Stepper & Servo MotorsReplies: 7Last Post: 13-02-2013, 07:07 PM
