    Hi Terry, I've got Igus cables and cable chains and never had any issue. If I remember correctly my stepper cables are CF10.07.04 but I chose this model because I have very small bend radius chain.
    Hi Paulus,
    Thank you for the info. I will have a look. To be honest I have no idea. I think I will do all 3 cables while I'm at it. Thanks again mate. really appreciate it. Terry.
    Quote Originally Posted by wrighty View Post
    Hi Paulus,
    As Rob has said I would suggest 4 core 0.75mm CY cable and connect the screen at the control box end to a star point (ie where all the ground points are connected)
    Hi Clive, thank you. I'm going to try to get the cable today as I want to get the cnc back up and running. Thanks for your help and will let you know how I get on. I will have to have a look at how I'm going to ground the screen at the control box end. Thanks again, Terry.
    Strip back the sheaf and solder a wire to the screen about 150mm long folded back along the cable and heat shrink over it, then fix that wire to a common earth point.
    Thanks Clive, That's made things easier now I know what to do. Great advice mate, Thank you. Terry.
    Hi Guy's I just want to say thanks for your help. I'm all up and running again and all seems good at the moment. Fingers crossed lol. Thanks again guy's, really appreciate your help. Terry.
  1. Stepper problem
    By eurikain in forum Stepper & Servo Motors
    Last Post: 19-12-2015, 03:25 PM
  2. Removing stepper motor problem from sherline mill
    By Neeps in forum Sherline Mills
    Last Post: 12-04-2015, 12:09 AM
  3. How do I wire a stepper driver to a stepper motor?
    By swood1 in forum Stepper & Servo Motors
    Last Post: 21-09-2014, 05:40 PM
  4. Replies: 1
  5. Stepper motors - problem
    By dudz in forum Stepper & Servo Motors
    Last Post: 13-02-2013, 07:07 PM
