    I only just managed to complete the required building work and insulation prior to it's arrival, now I just have to get the cable trays in and the workshop wiring upgraded to and then I can power it up :D
    George of Emvio Engineering dealt with absolutely everything up to the delivery to my chosen location in the UK, I can't recommend him highly enough, from my point of view it was a very smooth, hassle free and worry free process.
    Lives in East Lothian, United Kingdom. Last Activity: 14 Hours Ago Forum Superstar, has done so much to help others, they deserve a medal. Has a total post count of 2,994. Received thanks 376 times, giving thanks to others 9 times.
    We need more pics!
    However I notice you've pretty much went all out on the spec and accessories.
    One from the front
  5. The Following User Says Thank You to magicniner For This Useful Post:
  6. #4
    You won't miss that 4th axis, will you? :-)
    PS. it doesn't happen to take 30/60degree BT30 pull studs does it?
    I may know some idiot who just ordered 20 of them without checking they were the correct ones for their own machine
  7. The Following User Says Thank You to m_c For This Useful Post:
  8. #5
    Hmm, I kinda might, especially as it's permanently wired, I think I'd spot the ragged end of the cables! ;-)
    The plan is to hang it from a hoist above the machine whilst machining arrays of parts when it's not in use.
    Sadly not, it's the 45 degree.
    This is a view in through the left side door -
  9. The Following User Says Thank You to magicniner For This Useful Post:
  10. #6
    I wouldn't be that crude, I'd tape the wires up for you. :-)
    It does look like a good machine, and probably about the ideal size I'd like for some light production work, but my Triac ticks the boxes I need for now.
    If I'm ever down your way, I might have to visit and see how it is in the flesh.
  11. The Following User Says Thank You to m_c For This Useful Post:
  1. Mach3 and returning to cut position
    By dfox1787 in forum Artsoft Mach (3 & 4)
    Last Post: 07-07-2018, 10:06 AM
  2. Looking for a trainee position as a cnc operator
    By reefy86 in forum General Discussion
    Last Post: 07-06-2018, 08:19 PM
  3. Spindle position sensor
    By GeoffV in forum Motor Drivers & Controllers
    Last Post: 23-03-2014, 10:00 PM
  4. Position feedback
    By D.C. in forum Electronic Project Building
    Last Post: 17-10-2012, 11:30 AM
  5. router jumping position
    By johngoodrich in forum Linear & Rotary Motion
    Last Post: 23-09-2011, 06:31 PM
