Thread: Does it matter?
08-03-2019 #1
Hello, I got a question about choosing a breakout board for my cnc. I bought a uc300eth motion controller, along with 3 dm542t drivers, now I just need the breakout board. I've seen a lot of 5 axis boards that are relatively cheap, but they say they're for Mach 3. My problem is that I can't actually find any boards for Uccnc instead of for Mach 3/4. Does it actually matter though? Are breakout boards specifically configured to a single software somehow? Or can I use a Mach 3 breakout board for Uccnc? I understand that motion controllers are specifically configured to their own software (ie- Uccnc won't work on a warp 9 smoothstepper since smoothstepper is configured to Mach 3/4). But is this the same case for breakout boards???
Thanks in advance!!!!!
Sent from my Moto G (5) using Tapatalk
08-03-2019 #2
Hi jtar,
Mach is compatible with uc300eth.
UCCNC is exclusive to UCx controllers.
What version uc300eth do you have? 5lpt?
I have that one and used the cheap 5 axis board.(2 of them)
Mine came with the PP flatcable, port 2 and 3 are standard compatible with those.
The 5 axis bob is 1 on 1 compatible on port 2 and 3.
There is no software in the bob.
i had a budget consideration, and would rather have had ub1 bob icw uc300eth.
Hope this helps.
Grtz Bert.
11-03-2019 #3
12-03-2019 #4
My take is that its all a matter of 0's and 1's and if the board has enough connections and you assign them to the functions you need there ought not to be a problem.I used the much maligned DB25-1205 board that came bundled with my Long's motor kit to run with LinuxCNC and it works.I might not be able to produce parts at the rate of a large furniture factory but for a hobby machine I have no complaints.
Video: How thick is a sharpie mark, dose colour matter?
By Lee Roberts in forum Workshop & EquipmentReplies: 2Last Post: 23-04-2016, 12:23 AM -
whats the matter!
By ptjw7uk in forum General DiscussionReplies: 18Last Post: 29-11-2009, 07:21 PM -
Sortout - free to good home - or bad one for that matter
By John S in forum Marketplace DiscussionReplies: 1Last Post: 06-07-2009, 12:52 PM
