    I did a new 445nm 2W Laser Diode engraver build using a Shapeoko 2 with an Arduino UNO and GRBL Shield to control it. Here is a 8bit, analog modulated Laser Diode engraving I did on Birch Ply with this machine. The engraving is 9" X 7.5".
ID:	13526   Click image for larger version.
    Extensivly Re-worked/Re-designed/Modified Servo K2CNC KG-3925,
    Mini Laser Diode Engraver and PicEngrave Pro 4 + Laser
    Shapeoko 2 Laser Diode Engraver-Analog/TTL
    PicLaser Lite; Image to Gcode for 9g grbl/Mach3 controllers-Laser/Spindle
    PicEdit Lite: Image editing for use with PicLaser Lite
    PicSender: Streams 9g grbl Raster/Vector Engraving gcodes
    https://picengrave.com
    Impressive -thanks for showing. G.
  3. The Following User Says Thank You to GEOFFREY For This Useful Post:
    Thank you GEOFFERY.
    Here is information on our Shapeoko 2 laser engraver build.
    http://www.instructables.com/id/Shap...t-Raster-Phot/
    Jeff
  5. #4
    We just finished a new build on our Shapeoko 2 using a 6W 450nm laser Laser Diode from DTR. We were able to reduce the 3D engraving time almost in half compared to using a 2.8W 445nm LD on the examples shown here.
    http://forum.darklylabs.com/index.php?p=/discussion/362/3d-engraving-using-picengrave-pro-5
    We are still refining the settings in PicEngrave Pro 5, but here are the results of a 3D engraving we did. It's 7.875" X 5.25" in size with a.125" total depth of cut. We used the J-Tech PWM grbl with S20-S255 laser power commands, a variable feedrate (Feed Rate Change) and streamed the 507,365 lines of gcode with our PicSender program.
    www.picengrave.com
Name:	3D LionsS.jpg
ID:	15903   Click image for larger version.
  6. #5
    Looks great! How long did it take to do?
  1. Laaser Diode Engraving with PicEngrave Pro 4
    By Picengraver in forum Woodworking Project Showcase
    Last Post: 27-12-2015, 12:31 AM
  2. Laser diode module machine addon
    By luke11cnc in forum Laser Machines & Building
    Last Post: 06-01-2014, 11:24 PM
  3. Replies: 0
    Last Post: 12-11-2013, 09:31 PM
  4. Laser engraving slate
    By Philly in forum Laser Machines & Building
    Last Post: 18-11-2012, 08:19 PM
  5. Laser Diode Constant Current Driver
    By Mad Professor in forum General Electronics
    Last Post: 21-07-2010, 06:01 PM
