09-03-2019 #11
The Following User Says Thank You to Voicecoil For This Useful Post:
09-03-2019 #12
The big issue is as the motor spins faster, the back emf increases (emf = Electromotive Force, essentially voltage). Back emf is why you need a higher voltage supply, as in order to over come the emf and 'force' enough current through the windings, you need a higher voltage.
A modern drive only controls current which in turn limits voltage. The voltage over a motor coil, is related to the back emf being produced (higher inductance = higher back emf), with the highest voltage being the maximum supply voltage. As back emf reaches the point at which the supply voltage is unable to fully overcome the back emf, the coil current starts to decrease (and torque, as motor torque is proportional to current)
Now the problem comes when you have too much speed, and too much voltage.
Take the motors in question, with their recommended 57V, and 4.2A current. At a high enough speed to use the full 57V, the motor is using around 240W. Bump that to 70V, and power jumps to 294W, about a 20% jump.
Now can the motor dissipate that much heat?
(not all that power ends up as heat, but steppers are not that efficient)
It's where you've got to judge where you want to compromise.
If you never run the motors that fast, a higher voltage supply is not likely to be an issue.
You could reduce motor heating by reducing the current, but then you loose torque.
Ultimately, the best measure is how quickly the motors heat up in use.
If they get too hot to touch within a couple minutes of running, you've probably already cooked and demagnetised the rotor, and now have a poorly performing paperweight. Rotor overheating is what will kill a stepper motor, and as it's got no direct cooling, you're relying on heat transfer to the motor body to cool it, and that heat transfer is pretty poor.
If however after an hours running, they reach and plateau around 60-80deg C, you've probably got them on their ideal limit.Avoiding the rubbish customer service from AluminiumWarehouse since July '13.
The Following 2 Users Say Thank You to m_c For This Useful Post:
10-03-2019 #13
Thanks for explanation :) it seems I have 3 options then...
1. Risk the 3.1Nm (57v) steppers with the 70v PSU
2. make a lower voltage supply for the 3.1Nm steppers
3. choose the less powerful 1.89Nm stepper which is 81v?
Option 3 seems like a step back to me though so I may try and build the supply and see what voltage I get and decide whether to change out the Toroidal transformer.
Cheers Guys
The Following User Says Thank You to CharlieRam For This Useful Post:
10-03-2019 #14
Hi charlieRam.
I think what everybody is saying: there is no real risk.
Else they would say:
Dont do it, it is going to fail.
People here will tell you if your going in the wrong direction.
What i am reading between the lines is :
- They key factor is limitting the max current in the stepper driver settings.
- Higher voltage is an advantage to go fast.
- To high voltage can become a problem. -
- You need to check while running at max performance (rpm) for long periods.
I guess you will not be running at max rpm all the time.
Steppers are easily monitored by checking the temperature of the steppers.
Do this while commisioning the setup and learn to know your machine.
For me, motor calcs advised 57 volts. I run 4nm nema23 steppers, i have unregulated 72volts psu.
Until now i run 15% under max current.
I have to check software driver setup to set my drivers at the exact max.
My steppers never get above 40 deg.
My drivers reduce to 50% current at hold conditions
I have no performance issues.
I calculated for 2m/min cutting speed @50N cutting forces.
I have been cutting mdf @ 3m/min.
I am very happy with the guidance i got from here.
Grtz Bert.
The Following User Says Thank You to driftspin For This Useful Post:
10-03-2019 #15Exactly All the machines I have done the motors have never gone above 40C. There is a big difference between theory and practice, too many variables.I think what everybody is saying: there is no real risk.
Very seldom will the motors draw full current...Clive
10-03-2019 #16
Cheers guys 😁
18-03-2019 #17
I was just looking at those drives and tried to search for ones in the european union to avoid any duty but are these fake? it says the max voltage on the drive is only 70v DC!
https://www.ebay.co.uk/itm/Stepper-M...EAAOSwyHxcfEjv
18-03-2019 #18
Try this one. https://www.ebay.co.uk/itm/NEW-CNC-2...EAAOSwikJb7QmM
18-03-2019 #19
What's the likelihood I'll get stung on import duties? What kind of cost should I expect to have to pay if I do get stung?
19-03-2019 #20
It all seems to depend on what shipping method is used. Typically for stuff coming by the big carriers (Fedex, DHL, UPS etc.) it'll be 4 to 5% duty, a handling fee of between £10 and £15 and then 20% VAT on the whole lot.
Powering 3 45Ncm Nema 17 Stepper Motor 2A 4-wire (not CNC)
By Fivetide in forum Stepper & Servo MotorsReplies: 23Last Post: 22-11-2016, 01:32 AM -
FOR SALE: Nema 34 12Nm stepper motor
By dsc in forum Items For SaleReplies: 0Last Post: 08-05-2014, 01:14 PM -
FOR SALE: Nema 23 4Nm Stepper Motor
By Shinobiwan in forum Items For SaleReplies: 16Last Post: 07-02-2013, 02:15 PM -
Simple Solution- Drive 1" Ball Screw Shaft with NEMA-23-Size Stepper Motor Shaft
By LoveLearn in forum Gantry/Router Machines & BuildingReplies: 5Last Post: 08-02-2012, 01:52 AM -
Stepper motor advice for absolute novice
By mbgnjdb5 in forum Stepper & Servo MotorsReplies: 2Last Post: 07-05-2011, 04:47 PM
