09-03-2019 #2
Going by the key spec (current and inductance), they are pretty much identical motors.
However I'd say 70V is too high. The recommended max voltage is 32 * SQRT(L) (L is inductance), which puts the recommended max voltage around 57VDC when running with parallel/unipolar wiring.
A higher voltage won't have much effect at lower speeds, however if you're running at higher speeds, overheating is likely to become an issue if running at the rated current.Avoiding the rubbish customer service from AluminiumWarehouse since July '13.
Powering 3 45Ncm Nema 17 Stepper Motor 2A 4-wire (not CNC)
By Fivetide in forum Stepper & Servo MotorsReplies: 23Last Post: 22-11-2016, 01:32 AM -
FOR SALE: Nema 34 12Nm stepper motor
By dsc in forum Items For SaleReplies: 0Last Post: 08-05-2014, 01:14 PM -
FOR SALE: Nema 23 4Nm Stepper Motor
By Shinobiwan in forum Items For SaleReplies: 16Last Post: 07-02-2013, 02:15 PM -
Simple Solution- Drive 1" Ball Screw Shaft with NEMA-23-Size Stepper Motor Shaft
By LoveLearn in forum Gantry/Router Machines & BuildingReplies: 5Last Post: 08-02-2012, 01:52 AM -
Stepper motor advice for absolute novice
By mbgnjdb5 in forum Stepper & Servo MotorsReplies: 2Last Post: 07-05-2011, 04:47 PM
