    Clive, Are you saying the 57v rated Steppers will be fine with the 68V PSU and either of those drivers? I am sure this is what people have used in the past but m_c says the voltage is too high! I'm a little confused now.
    Personally I would go with the 68V p/s with the drives above or https://www.ebay.co.uk/itm/2DM860H-2...frcectupt=true
    There are plenty of people using this setup without problems
    I saw those drives but was a little unsure....have many people used them? It doesn't look like it has stall detection although I do understand that if the motor has stalled the job will be wrong even with stall detect.
    It's worth doing the sums and working out exactly what voltage you need - for some motors 50V would be fine, for others a big hindrance. Thankfully, @Irving2008 has put it all into a handy-dandy spreadsheet which ties together all the variables (apart from using pulleys/gears with a non 1:1 ratio) for which he deserves a beer - go looky here:
    http://www.mycncuk.com/threads/1524-...tor+calculator
    This is part of my problem...the spreadsheet says the motor has a good margin but will it be ok on a 70v power supply?? Click image for larger version.
    Quote Originally Posted by CharlieRam View Post
    As long as you set the current limit on the drivers correctly, it didn't ought to be a problem. OK the current will rise quicker, but the peak current should be the same as it would be with a lower voltage, it'll just happen quicker.
  5. The Following User Says Thank You to Voicecoil For This Useful Post:
  6. #5
    Lives in East Lothian, United Kingdom. Last Activity: 7 Hours Ago Forum Superstar, has done so much to help others, they deserve a medal. Has a total post count of 2,992. Received thanks 376 times, giving thanks to others 9 times.
    The big issue is as the motor spins faster, the back emf increases (emf = Electromotive Force, essentially voltage). Back emf is why you need a higher voltage supply, as in order to over come the emf and 'force' enough current through the windings, you need a higher voltage.
    A modern drive only controls current which in turn limits voltage. The voltage over a motor coil, is related to the back emf being produced (higher inductance = higher back emf), with the highest voltage being the maximum supply voltage. As back emf reaches the point at which the supply voltage is unable to fully overcome the back emf, the coil current starts to decrease (and torque, as motor torque is proportional to current)
    Now the problem comes when you have too much speed, and too much voltage.
    Take the motors in question, with their recommended 57V, and 4.2A current. At a high enough speed to use the full 57V, the motor is using around 240W. Bump that to 70V, and power jumps to 294W, about a 20% jump.
    Now can the motor dissipate that much heat?
    (not all that power ends up as heat, but steppers are not that efficient)
    It's where you've got to judge where you want to compromise.
    If you never run the motors that fast, a higher voltage supply is not likely to be an issue.
    You could reduce motor heating by reducing the current, but then you loose torque.
    Ultimately, the best measure is how quickly the motors heat up in use.
    If they get too hot to touch within a couple minutes of running, you've probably already cooked and demagnetised the rotor, and now have a poorly performing paperweight. Rotor overheating is what will kill a stepper motor, and as it's got no direct cooling, you're relying on heat transfer to the motor body to cool it, and that heat transfer is pretty poor.
    If however after an hours running, they reach and plateau around 60-80deg C, you've probably got them on their ideal limit.
  7. The Following 2 Users Say Thank You to m_c For This Useful Post:
  8. #6
    Thanks for explanation :) it seems I have 3 options then...
    1. Risk the 3.1Nm (57v) steppers with the 70v PSU
    2. make a lower voltage supply for the 3.1Nm steppers
    3. choose the less powerful 1.89Nm stepper which is 81v?
    Option 3 seems like a step back to me though so I may try and build the supply and see what voltage I get and decide whether to change out the Toroidal transformer.
    Cheers Guys
  9. The Following User Says Thank You to CharlieRam For This Useful Post:
  10. #7
    Cheers Guys
    Hi charlieRam.
    I think what everybody is saying: there is no real risk.
    Else they would say:
    Dont do it, it is going to fail.
    People here will tell you if your going in the wrong direction.
    What i am reading between the lines is :
    - They key factor is limitting the max current in the stepper driver settings.
    - Higher voltage is an advantage to go fast.
    - To high voltage can become a problem. -
    - You need to check while running at max performance (rpm) for long periods.
    I guess you will not be running at max rpm all the time.
    Steppers are easily monitored by checking the temperature of the steppers.
    Do this while commisioning the setup and learn to know your machine.
    For me, motor calcs advised 57 volts. I run 4nm nema23 steppers, i have unregulated 72volts psu.
    Until now i run 15% under max current.
    I have to check software driver setup to set my drivers at the exact max.
    My steppers never get above 40 deg.
    My drivers reduce to 50% current at hold conditions
    I have no performance issues.
    I calculated for 2m/min cutting speed @50N cutting forces.
    I have been cutting mdf @ 3m/min.
    I am very happy with the guidance i got from here.
    Grtz Bert.
  11. The Following User Says Thank You to driftspin For This Useful Post:
  12. #8
    I have always used 68 V with no troubles, everybody has their own opinion so you have to make your own mind up.
    I found them about 2 years ago and have used about 8 of them Dean (Jazzcnc) I think has used more than 12. re the stall detect you are correct they don't have it. But the AM882 and EM806 does have it but if I remember correctly it only kicks in at about 300 rpm.
    As m_c has stated go with a parallel setup.
  1. Powering 3 45Ncm Nema 17 Stepper Motor 2A 4-wire (not CNC)
    By Fivetide in forum Stepper & Servo Motors
    Last Post: 22-11-2016, 01:32 AM
  2. FOR SALE: Nema 34 12Nm stepper motor
    By dsc in forum Items For Sale
    Last Post: 08-05-2014, 01:14 PM
  3. FOR SALE: Nema 23 4Nm Stepper Motor
    By Shinobiwan in forum Items For Sale
    Last Post: 07-02-2013, 02:15 PM
  4. Simple Solution- Drive 1" Ball Screw Shaft with NEMA-23-Size Stepper Motor Shaft
    By LoveLearn in forum Gantry/Router Machines & Building
    Last Post: 08-02-2012, 01:52 AM
  5. Stepper motor advice for absolute novice
    By mbgnjdb5 in forum Stepper & Servo Motors
    Last Post: 07-05-2011, 04:47 PM
