Thread: Evening all
Hi all, and thanks in anticipation!
I'm hoping to get some advice on my first CNC router, required for a specific purpose.
I'm an electronics engineer by training, working on military EMC projects, and a background in military aviation but have many engineering related hobbies such as RC Aircraft, electronics, radio, and mechanical engineering.
I have a small bench mill, and a larger (340mm swing) lathe, and my main interest here is building hifi turntables / arms. I have a fair few behind me now. Even though I started out building for myself, I now have a few customers and a fair bit of interest, so to this end I'm looking to improve repeatability, and expand the scope of what I can do.
Anyhow, thanks for having me - I'll go off and post in the machines section to see if I can get some hints as to what I should be looking at!
14-03-2019 #2
A router will potentially give you a larger work area than a mill for a given spend but with reduced mass and rigidity. The results is that lighter cuts are required in the materials it will handle than with a mill in order to avoid spindle deflection and vibration and harder materials.
Have you considered converting your mill to CNC?You think that's too expensive? You're not a Model Engineer are you? :D
14-03-2019 #3
I'm looking for a bed size that will cope with a record deck plinth - probably in acrylic - maximum size around 500 x 400 x 50, so my little mill is out. I'd also like it to be able to cope with small aluminium items.
NEW MEMBER: Evening All
By Chimestrike in forum New Member IntroductionsReplies: 37Last Post: 08-09-2016, 10:17 PM -
NEW MEMBER: Evening all
By 9designs in forum New Member IntroductionsReplies: 6Last Post: 25-11-2014, 06:52 AM -
NEW MEMBER: Good evening all.
By monza in forum New Member IntroductionsReplies: 2Last Post: 28-12-2009, 08:53 PM -
NEW MEMBER: Good evening.
By itbookham in forum New Member IntroductionsReplies: 1Last Post: 18-11-2009, 08:46 PM -
NEW MEMBER: Evening all.....
By HiltonSteve in forum New Member IntroductionsReplies: 9Last Post: 14-05-2009, 02:40 PM
