    Hi all, I have been researching a 3 axis stepper motor kit, from the advice I have been given this forum, I have decided to go with a 80v set up, have seen some stepper motors from cnc4you, they are 8 wire 4Nm model number 60BYG401-03, and also the drivers to match which are 6.0A, 80V CNC Microstepping CW8060, also from cnc4you, i need advice on the the psu and the breakout board to with the motors and drivers, I am not quite sure which would best, either from cnc4you or elsewhere. Any advice would be very much appreciated. Thanks Paul
    Quote Originally Posted by Paul53 View Post
    Hi Paul53,
    Checkout post #95 in my buildlog.
    Clive S pointed out the parts for a diy psu.
    https://r.tapatalk.com/shareLink?url...2&share_type=t
    It is excelent advice.
    When i measure voltage there is only about 2 volt drop at max speed running all 4 4nm nema 23 steppers.
    I have 235volt input 72volt output rectified.
    I have 3 4700 capacitors.
    Did you say you have the UC300eth ?
    Best board out there is sold by:
    https://www.cncroom.com/interface-cards/uc300eth-ub1
    Also sold separately.
    https://www.cncroom.com/interface-cards/ub1
    It is expensive though.
    I went for cheap dual 5 axis boards.
    I added cheap relays.
    I have all the IO i need.
    There was some tinkering needed to run 24v signaling icw cheap boards.
    UB1 has native 24v support for IO.
    Checkout the diy psu video from Joe Harris
    https://youtu.be/4OoQQg76ar4
    Grtz Bert.
    Lives in Marple Stockport, United Kingdom. Last Activity: 13 Hours Ago Forum Superstar, has done so much to help others, they deserve a medal. Has a total post count of 3,342. Received thanks 618 times, giving thanks to others 82 times. Made a monetary donation to the upkeep of the community. Is a beta tester for Machinists Network features.
    For the machine I think you have I would just use a simple bob to get you going if the PC has a PP https://www.ebay.co.uk/itm/5-Axis-CN...gAAOSwHUlbkLzl
    Hi Clive, regarding the machine, I have basically stripped it down, I am rebuilding the whole thing, replacing wooden frame with 10mm aluminium plate, everything is being made out of this, the spindle mount, side supports etc, the only thing I am using is the spindle (water cooled) and the inverter, so basically starting again, haven't decided whether to mount all the drivers etc in a pc case or get/make a purpose built control box
  1. Putting Bearing on Drill
    By Tenson in forum Linear & Rotary Motion
    Last Post: 29-10-2015, 05:02 PM
  2. Replies: 3
    Last Post: 01-11-2014, 09:28 PM
  3. How do I wire a stepper driver to a stepper motor?
    By swood1 in forum Stepper & Servo Motors
    Last Post: 21-09-2014, 05:40 PM
  4. Replies: 1
  5. Zapp 3-Axis kit - putting it all together
    By birchy in forum Motor Drivers & Controllers
    Last Post: 18-02-2013, 12:05 PM
