Hi Paul53,
Checkout post #95 in my buildlog.
Clive S pointed out the parts for a diy psu.
https://r.tapatalk.com/shareLink?url...2&share_type=t
It is excelent advice.
When i measure voltage there is only about 2 volt drop at max speed running all 4 4nm nema 23 steppers.
I have 235volt input 72volt output rectified.
I have 3 4700 capacitors.
Did you say you have the UC300eth ?
Best board out there is sold by:
https://www.cncroom.com/interface-cards/uc300eth-ub1
Also sold separately.
https://www.cncroom.com/interface-cards/ub1
It is expensive though.
I went for cheap dual 5 axis boards.
I added cheap relays.
I have all the IO i need.
There was some tinkering needed to run 24v signaling icw cheap boards.
UB1 has native 24v support for IO.
Checkout the diy psu video from Joe Harris
https://youtu.be/4OoQQg76ar4
Grtz Bert.
Verstuurd vanaf mijn SM-A320FL met TapatalkLast edited by driftspin; 15-03-2019 at 07:38 PM.
Putting Bearing on Drill
By Tenson in forum Linear & Rotary MotionReplies: 10Last Post: 29-10-2015, 05:02 PM -
Putting Neodymium Strong magnets near spindle ..is it ok ?
By RoyT in forum General DiscussionReplies: 3Last Post: 01-11-2014, 09:28 PM -
How do I wire a stepper driver to a stepper motor?
By swood1 in forum Stepper & Servo MotorsReplies: 7Last Post: 21-09-2014, 05:40 PM -
Stepper Motor Driver - cheap similar to ArcEuro 4.2A Bi-Polar Stepper Motor Driver
By craynerd in forum Motor Drivers & ControllersReplies: 1Last Post: 16-03-2014, 07:29 PM -
Zapp 3-Axis kit - putting it all together
By birchy in forum Motor Drivers & ControllersReplies: 5Last Post: 18-02-2013, 12:05 PM
