    Hi everyone.
    I have just finally got my machine cutting.
    Though it is working very nicely, I feel that i will need to add some drag chains to the gantry (Y in my case) and Z axis. I have been looking at some on ebay and am not sure which to get (some look a bit crap).
    At this point I don`t want to re-wire everything so need to be able to open the chain and slide in the wires and coolant tubes. The Z axis has quite a lot of wiring and tubes so it needs to be quite fat as well.
    Currently I have controlled the wires with a length of bungee from the ceiling and some zippy ties.
    Just wondering if there is a go-to brand or type for these chains, or any other recommendations or experience with them ?
    Similar question with the switches really.
    When i bought the machine it had one switch on the Z and one on the Y axis, oddly these were wired into one port on the BOB along with the E stop switch. I have removed the switches from the BOB for now and just left the E stop functioning.
    I plan to use a spare breakout board and wire 5 limit switches to it then into the UC300 eth. So one each end of the X and Y and one at the top of the Z. Then set up homing on the same switches.
    The old Switches are roller lever micro switches. However i went on RS components to look for `limit switches` and found an enormous range of types and prices. Any recommendations?
    I am cutting wood mostly so no coolant splashing about but obviously dust.
    Ollie
  2. The Following User Says Thank You to Ollie78 For This Useful Post:
  3. #2
    I don't think there is a go-to for this (energy chain) and people just source it from wherever, you can get it all over ebay but keep an eye out as some don't allow you to get the cables in like your after without threading it in, this version has quite good feedback: 15x30mm Black Semi Enclosed Towline Cable Chain Drag Carrier Track
    Igus make a very nice one with quite a few options: Energy Chains Overview e2.1
    and I know a few of our members have used the one available from Motedis a UK company: https://www.motedis.co.uk/shop/table...hp?table_id=52, if you let them know your coming from mycncuk you may also get a discount
    Re Switches:
    Most are using proximity switches/sensors rather than micro switches now days, below is a video showing some differences so you can get a better idea on how they work and how you can use them, 1 at each end of an axis with a moving "target" to trigger...simple's !
    Last edited by Lee Roberts; 19-03-2019 at 10:48 PM. Reason: added info for switches
  4. The Following User Says Thank You to Lee Roberts For This Useful Post:
  5. #3
    and a demo showing 2 wired in parallel:
  6. The Following User Says Thank You to Lee Roberts For This Useful Post:
  7. #4
    mekanik's Avatar
    Lives in Barrow in Furness, United Kingdom. Last Activity: 10 Hours Ago Has a total post count of 803. Received thanks 101 times, giving thanks to others 176 times.
    Hi Ollie
    Try These, Boyan seems to think there the mutt's nut's
    http://www.cable-tracks.com/
    Regards
    Mike
  8. The Following User Says Thank You to mekanik For This Useful Post:
  9. #5
    Cheers for the replies.
    I have further questions....
    It looks like proximity sensors are a good way to go, no moving parts to go wrong. from what I gather though I will need an extra 24v power supply for these. Why so high a voltage ? I think the switches on my machine were just powered off the 5v BOB
    Can you get 5v ones? Seems a bit of a pain to have to step down the signal to 5v with resistors etc.
    I am also a bit puzzled by the purpose of wiring them in parallel. I guess for just stopping the machine in an emergency it doesn`t matter but if I want to use them for homing won`t I need to tell which one is which. I have 5 inputs on the spare
    BOB so one each should be ok.
    Is normally closed better so if something breaks they trigger ?
    Are this type Ok https://www.ebay.co.uk/itm/TL-Q5MC2-...frcectupt=true
    They look easier to mount than the round threaded ones.
    As for the energy chains those ARKO ones do look posh, and a good price too. I will investigate the postage / customs implications and see how they compare to the others. I like the little separator bits to guide the cables within the chain, very neat.
    Ollie
  10. The Following User Says Thank You to Ollie78 For This Useful Post:
  11. #6
    Hi Ollie,
    The best way to go is using both switches wired in series with the estop and sensors for homing/soft limits. 24V is the industrial standard as it is more resistant to noise/interference/contact oxidation/etc.
    You do not need to step down the signal if using NPN sensors and your controller allows you to use NPN.
    Having the sensors wired to separate inputs allows you to home all axes simultaneously. No other major benefits.
    The safety limit switches need to be wired NC, for the sensors it doesn't matter.
    I have no experience with the no-name sensors as I was using only expensive ones. You can use one sensor for each axis if you mount them on the moving part while having two end-targets.
    I have used only Igus cable chains. They are not the cheapest but very good industrial quality.
  12. The Following User Says Thank You to paulus.v For This Useful Post:
  1. Drag chain size and length needed for 6040 CNC
    By nirmal in forum Chinese Machines
    Last Post: 02-05-2016, 11:24 AM
  2. Which Type of Limit Switch
    Last Post: 29-07-2014, 03:43 PM
  3. Cable drag chain
    By birchy in forum General Electronics
    Last Post: 04-01-2014, 12:45 AM
  4. chain drive
    By jonm in forum Linear & Rotary Motion
    Last Post: 07-03-2010, 02:36 PM
  5. WANTED: Energy chain
    By Smiler in forum Items Wanted
    Last Post: 16-08-2008, 07:13 PM
