Thread: better than smooth stepper
30-09-2009 #1
I'm looking for something that is better than a smooth stepper to connect a computer with a machine.
If someone knows something, please tell me.
30-09-2009 #2
Take a look at the EMC2 hardware page, it lists the Galil and other motion controlers, there might also be a page on the Mach site.
01-10-2009 #3
Because you mention the Smooth Stepper which only works with Mach3, then I presume that is the controller you are asking about.
First off, have you considered the LPT? First and best option for Mach output IMO. Depends what pulse rate you need.
The later PCI Galil cards work with Mach3. They would be a step up.
About ten times the price of the SS unless you can get a second hand one.
Look on the Mach support forum for info on the Galil plugin.
Greg
01-10-2009 #4
Do you need it to work with Mach 3? if not there are loads of CNC controllers out there.
If it needs to work with Mach 3, you will be restricted.
Most of the CNC controllers that dont work with Mach, also dont need a PC.Last edited by Gary; 21-10-2009 at 01:30 PM.
Visit Us: www.automationshop.co.uk
21-06-2010 #5
I would suggest you to take a look to the COLIBRI by twintec, it's becamened the most used on the Italian cnc forum, it works very well and all the feature are almost ready , many people moved from mach3 and the smooth stepper to this controller, the software is free and so all the upgrade relased.
http://www.twintec.it/colibri.htm#colibri_controller
The site have the english(ish) version as well
M.Last edited by massimomb; 21-06-2010 at 05:10 PM.
21-06-2010 #6
If you want a controller you could look at http://www.eaziform.co.uk/index.php?products,m401 only drawback is the serial port needed as most laptops now dont have them!
Peter
how to smooth stl model, smooth curves out of straight lines
By chris in forum DeskProtoReplies: 4Last Post: 21-01-2014, 11:00 PM -
Smooth Steppers are finally available in UK !
By rnr107 in forum Marketplace DiscussionReplies: 63Last Post: 13-07-2012, 12:53 AM -
FOR SALE: Smooth Stepper board Plus C24 and C25 BOB
By AdCNC in forum Items For SaleReplies: 2Last Post: 11-09-2011, 09:56 PM -
FOR SALE: Smooth Stepper (UK)
By lateAtNight in forum Items For SaleReplies: 2Last Post: 24-06-2010, 10:19 PM
