    Hello all.
    I'm in the process of choosing proximity and homing switches. I have noticed that there are different sensing distance switches from 1 to 4 mm are there any benefits in choosing switches with a 1mm sensing distance (are they going to be more accurate for homing?) Any other information gratefuly accepted ie npn or pnp.
    Cheers Andrew
    Quote Originally Posted by the great waldo View Post
    Hello all.
    Cheers Andrew
    Hi waldo,
    I spend only €13,- on 5 units... m8 6-36 vdc 2mm sensing distance.
    Aliexpress
    lj8a3-2-z/bx npn
    Just a single meter of wire on the sensor.
    I use a sloped metal surface of about 20 deg for sensing.
    I am very impressed by the accuracy.
    homing is spot on on a cheap 0.01 mm tdi every time.
    They switch to negative / ground on contact.Almost no resistance compared to grond.
    In the off position they have about 10k series resistor in the switching wire
    Had to do some tinkerring with resistors to interface with the cheap 5 axis Bob i have.
    Not sure what your budget is for them or what controller electronics you have.
    Grtz Bert.
  3. The Following User Says Thank You to driftspin For This Useful Post:
    With proximity sensors you could use two switches in series, one sensing axis position directly and the second sensing a cam on the rotating screw - instant multiplication of homing resolution ;-)
  5. #4
    That is actually a very good idea.
  6. #5
    I'll be using it on my Chester mill conversion, I've decided to get my new VMC up and running first and make the rest of the parts for the conversion with the big CNC.
  7. #6
    Hi Magicniner
    Any chance of explaining the cam on the rotating screw (picture/sketch for a dummy might be helpful) If it's too much hassle don't worry, but I am curious.
    Andrew
  8. #7
    Anything with a high point that a proximity switch can sense at a repeatable point in the homing direction will do, you could use a single bladed chopper too, anything which sticks out significantly more at one point in it's rotation will do.
    Mount the cam near one end of the screw and mount the proximity switch so that it is triggered by the cam.
    Simples! ;-)
    Here's a pic I found, imagine a gear with just one tooth.
  9. The Following 2 Users Say Thank You to magicniner For This Useful Post:
  10. #8
    Simples! ;-)
    HI magiciner.
    Only small disadvantage i can think of is that the sensor must be on the moving part.
    Good idea !
    Grtz Bert.
  11. #9
    Simples! ;-)
    Hi Magicniner.
    I hope this isn't a silly question but apart from the obvious what is a single bladed chopper in this case?
    Cheers.
    Andrew
  1. Help with setting up proximity sensors and Mach 3
    By Wooddesign in forum Gantry/Router Machines & Building
    Last Post: 10-03-2019, 09:27 PM
  2. Homing with proximity sensors
    By routerdriver in forum General Electronics
    Last Post: 19-12-2017, 06:32 PM
  3. Help with proximity sensors
    By D-man in forum General Electronics
    Last Post: 14-04-2016, 11:36 PM
  4. FOR SALE: Inductive proximity sensors
    Last Post: 26-01-2016, 06:05 PM
  5. FOR SALE: Proximity sensors
    Last Post: 13-09-2014, 08:02 AM
