    Hi all, im a new member and new to CNC machining, im looking to get a project prototyped and was woundering were is a good and cheap place to have it done, its a stand for my Stereo Microscope that uses Linear Bearings, note that you can buy this stand for about £280-350 and as you may have guessed I don't have that right now, I have had quotes to make it @£120 per part and there is 4 parts total all made in aluminium, has 3mm, 16mm, 28mm and 32mm holes mostley straight through, I will show a pic of one(the most complex one) below, what would you do to get it made ?
    Also it can be edited eg : remove the rounded edges and small holes that I can do at home.
    Thanks all for your input
    Brett
    When people ask me about making one-offs for them I always tell them that if someone already sells it in this country, almost regardless of price, that's going to be cheaper. I even do a comprehensive internet search and pass on any suppliers I can find.
    What you need is a Model Engineer, many of them place little value on their personal time and think everything should be cheap :D
    Regards,
    Nick
  3. The Following User Says Thank You to magicniner For This Useful Post:
    Same here. I am also new here.
  5. #4
    120 £ per part is very cheap for cross holes for linear bearings.
    They need accurate bores and accurate angles.
  1. Name the vfd part?
    By charlieuk in forum General Electronics
    Last Post: 17-01-2018, 07:05 PM
  2. RFQ: Need part
    By Buckis in forum Projects, Jobs & Requests
    Last Post: 21-02-2014, 01:21 AM
  3. RFQ: Part required machining
    Last Post: 21-10-2013, 02:46 PM
  4. Video of CNC machining a double sided part.
    By Shinobiwan in forum Woodworking Project Showcase
    Last Post: 17-03-2013, 11:23 AM
