Thread: Small cnc milling for aluminium
Hi Bret
Wouldn't even consider the cheap Chinese routers, not substantial enough to cut ally in any respectable time frame, from the last line of your post it appears that your best option would be a small milling machine if you are just doing facing cuts, however if you intend to drill precise holes or profiles a CNC mill would be a better option but your lack of budget seems to rule that out, also you would need the required skills to draw your design in a suitable CAD/CAM program. If your projects are simple comprising just flat faces ect this sort of work can be done on a lathe with a 4 Jaw Chuck, if you have the available space for this sort of kit, doesn't have to be anything fancy, might find something on a well known auction site.
Regards
Mike
01-04-2019 #2
ok thanks for the info, my issue with buying a cnc mill is having the space for it.
I would have thought to build one it would need to be in the 300 - 400 bead area range and that I could use a motor from some were.
To build a frame a decent one would cost the same as the cheap ebay machines. I don't mind building one over a few months but most I see tend to be bigish machines and I would want one that's around 450-500 square, do you think its possiable and what spindle motor would be a good choice ? could you use one from a decent drill/angle girnder or somethink ? im such a noob at this :D
Also I can use Fusion 360 and I do make desgins in it aswell.
Thanks for the input
Brett
01-04-2019 #3
Hi Bret
Best bet is to have a look @ some of the build logs (http://www.mycncuk.com/forums/282-Ga...hines-Building) this will give you some idea of what is required, you could build a machine from steel box section(cheapest option) you don't need to be a brilliant welder to stick one together, others might be able to advise regarding motors/power supplies ect. rule number one don't buy anything until you have a CAD design for the guys to look @ this will save you wasting money, all the information you need to build a machine is available on the forum you just need to do the research, any questions will be answered by the forum members.
Good Luck
Mike
The Following User Says Thank You to mekanik For This Useful Post:
02-04-2019 #4
You might find that a CNC conversion of a compact CNC mill with decent iron castings could be cost effective.
RFQ: Small round of aluminium cases. Small parts, 50 in total for first batch. 110x50x15m
By JOGARA in forum Projects, Jobs & RequestsReplies: 0Last Post: 07-05-2018, 07:18 PM -
RFQ: Small run of parts in aluminium
By CHudson in forum Projects, Jobs & RequestsReplies: 0Last Post: 06-10-2017, 04:12 PM -
WANTED: Small milling head
By johnsattuk in forum Items WantedReplies: 0Last Post: 14-03-2014, 08:54 PM -
WANTED: Small Milling machine
By pmcb1011 in forum Items WantedReplies: 1Last Post: 10-02-2012, 10:07 PM -
BUILD LOG: Small PCB milling toy
By irving2008 in forum DIY Router Build LogsReplies: 0Last Post: 04-10-2009, 09:44 PM
