I didn't expect to be able to do a straight swap (though it would be nice). Would I be better looking at a new spindle and building a new control box for it? It would certainly make swapping between spindles easier/
05-04-2019 #2
The BoB you have, I am certain, has 0-10v output to control spindle speed with a VFD and Spindle setup, so you don't need any more electronics apart from the VFD. The rest is setting it up in Mach3.
05-04-2019 #3
05-04-2019 #4
you may need a new psu to meet the spec of the new spindle
The Following User Says Thank You to andy_con For This Useful Post:
05-04-2019 #5
The Following User Says Thank You to cropwell For This Useful Post:
05-04-2019 #6
I probably can't afford quality so would settle for Chinese.
The Following User Says Thank You to ngwagwa For This Useful Post:
06-04-2019 #7
Have you seen this? https://www.youtube.com/watch?v=jfryQr10nbo - someone has added a 1.5kW spindle to a micro router.
The Following User Says Thank You to Doddy For This Useful Post:
06-04-2019 #8
Thanks for that it's ust what I am aiming at.
Help required with mill conversion / upgrade.
By swarf-boy in forum Milling Machines, Builds & ConversionsReplies: 8Last Post: 06-12-2018, 12:33 PM -
Upgrade to x axis required. MG or HG rail
By marbles in forum Rails, Guideways & BearingsReplies: 0Last Post: 10-12-2017, 01:51 PM -
Roland camm 2 pnc 2300 spindle upgrade help
By iampete in forum Gantry/Router Machines & BuildingReplies: 0Last Post: 01-09-2014, 03:17 PM -
Kress Spindle upgrade to a 2kw
By Metal pecker in forum Kress Milling MotorsReplies: 4Last Post: 05-05-2014, 12:22 PM -
advice on upgrade to 5 axis control
By alanb in forum General ElectronicsReplies: 17Last Post: 27-07-2012, 06:29 AM
