Threaded View
    good day -
    first off! i am not a machinist - so you will have to be a bt forgiving.
    i have a dilemma - i am working on this design - and the intent is that the (green) cylinder is to freely roll when applied to a surface (like a pizza cutter.)
    however - the binding barrel (blue) i sourced out at mcmaster-carr - i do not want to rotate. and i certainly don’t want to too tight as it will start to bend the channel.
    it’s also critical that the ends have no drive - but a nice polished-finished look.
    maybe an adhesive?
    i came across google images - where i can see a binding barrel with a hex at the base (like a carriage bolt) i think this would work - right?
    but i imagine it’s easy to drill the hole in the channel - but the hex shape not so?
    so i am at a loss.
    if you look at the reference in the yellow circle - the bolt is normally welded and then sanded off. i don´t like this look. (unless there’s a machine shop that could perform this with a better finish?)
    what are my options in achieving this function?
    best regards -
    jón
  1. RFQ: EN24 Bolt Price Required
    By carlswift in forum Projects, Jobs & Requests
    Last Post: 06-01-2017, 10:22 PM
  2. Bolt Selection thickness
    By grain_r in forum Metalwork Discussion
    Last Post: 06-01-2016, 10:55 AM
  3. Has anyone please got an idea where I could get a bolt like this?
    By suesi34e in forum Marketplace Discussion
    Last Post: 13-01-2015, 01:06 AM
  4. WANTED: bolt on rail and block bearings or what ever - what have you
    By nobby in forum Items Wanted
    Last Post: 13-05-2014, 10:22 AM
  5. Machine bed T bolt
    By Colin Barron in forum Gantry/Router Machines & Building
    Last Post: 02-10-2010, 11:20 PM
