indeed.
my primary concern is movement. is there an epoxy that i can use where the tube meets the channel?
09-04-2019 #2You think that's too expensive? You're not a Model Engineer are you? :D
The Following User Says Thank You to magicniner For This Useful Post:
11-04-2019 #3
The Following User Says Thank You to JEK5019 For This Useful Post:
11-04-2019 #4
11-04-2019 #5
It would help if you could give us an idea of what you are trying to achieve. I respect that you may not want to disclose the end use, but some indication of the forces involved may be useful. Also is the axle to be free to rotate in the yoke or must it be definitely fixed? Are you looking to scale up to produce many units, or are you making just one or two? What material is the roller? Will it be wet (aqueous), oily or dry in end use? Do you have a unit cost limit in mind?
If you wanted a quick bodge you could pop rivet a length of tube into the yoke.
BTW cm is not a preferred unit in engineering, metric users prefer mm. In the US they use inches a lot (but not excusively). Some of the Model Engineers in UK use imperial measure, while some of the absolute recidivists use Furlongs, Newtons per square fortnight, Firkins and Ducats per gross.
Oh! and BA screws.
The Following 2 Users Say Thank You to cropwell For This Useful Post:
12-04-2019 #6
thanks cropwell.
so i looked up the wallpaper seam roller you had mentioned - and the design i am working will work just like that, in fact! but unlike many of the designs, i came across - where the roller bracket is on one side only - my design will be built like an axle.
attached are several of these wallpaper seam rollers that more or less fit my goal and operation.
in my design goal - i am wanting to avoid any welding/sanding finished. i would prefer fasteners - but with no drives. very clean!
12-04-2019 #7
Maybe a domed starlock washer, which would push onto a solid shaft, would fit your requirements.
12-04-2019 #8
so the handle will be metal/wood lather operation.
the channel/bracket and the roller - all metal. no plastics.
the approximate pressure and use will be similar to that of the wallpapaer seam roller.
and lastly - if i can resolve this issue in the design and move forward - the goal will several hundred units at first. if i can market it well and proves successful - then definitely a few thousand thereafter.
also - i am living in iceland and it'll be costly to manufacture here. i am beginning to source out manufacturers throughout europe and states. i need to start some cost estimates
do you have recommendations for any machine shops to contact?
12-04-2019 #9
No, it's not.
Drive screws have a fast outer helix with a relatively high sharp profile, they are designed specifically for blind holes where the relative sizes can be chosen such that material distortion stays local to the hole walls, among other things they are commonly used to fix data plates to castings.
You could make the holes in the bracket a tighter fit to give a lot of hold and the hole in the tube the right size to prevent rotation and give adequate retention without distortion of the outer.
It's your job to experiment with drive screw size, tube hole size and wall thickness to get the materials behaviour you require for your application.You think that's too expensive? You're not a Model Engineer are you? :D
The Following 2 Users Say Thank You to magicniner For This Useful Post:
12-04-2019 #10
thanks magicniner. i guess it is a matter of experiment - much appreciated.
i'm currently using mcmaster as a source for stock items (as it allows me to drop in the actual 3d product into fusion 360 - enabling the design) however, their tube selection seems rather marginal.
do you have recommendations for manufacturers for smaller sized metal tubes?
RFQ: EN24 Bolt Price Required
By carlswift in forum Projects, Jobs & RequestsReplies: 0Last Post: 06-01-2017, 10:22 PM -
Bolt Selection thickness
By grain_r in forum Metalwork DiscussionReplies: 13Last Post: 06-01-2016, 10:55 AM -
Has anyone please got an idea where I could get a bolt like this?
By suesi34e in forum Marketplace DiscussionReplies: 31Last Post: 13-01-2015, 01:06 AM -
WANTED: bolt on rail and block bearings or what ever - what have you
By nobby in forum Items WantedReplies: 8Last Post: 13-05-2014, 10:22 AM -
Machine bed T bolt
By Colin Barron in forum Gantry/Router Machines & BuildingReplies: 0Last Post: 02-10-2010, 11:20 PM
