"to be always closed." - you'll have to explain that a bit more.
From what you're written I understand that you've got 0-10V from the Spindle board, and have "somehow" connected this via a connector system to the VFD (guessing through an analogue 10V input, referenced to Analogue ground - two wires). You would then also likely have to reconfigure the VFD to take an analogue input rather than, e.g. front panel control (assuming you're currently using the push buttons for speed control at the moment on the VFD). Of course, you'll also have to work out the forward/reverse discrete controls (although for now you can do this from the front panel).
I can't recall seeing which VFD you've got, if the generic "Huanyang" Chinese jobs then look at:-
PD001 - Run Command : set to 0 (front panel) or 1 (discrete input)
PD002 - Operating frequency (RPM) : set to 0 (front panel) or 1 (analogue input - what you want)
PD070 - Analogue input : set to 0 (0-10V)
PD044 - FOR : set to 2 (forward rotation)
PD045 - REV : set to 3 (reverse rotation)
Preston, eh?, that's handy - if you need a lift with the VFD settings.Last edited by Doddy; 19-04-2019 at 04:50 PM.
The Following 2 Users Say Thank You to Doddy For This Useful Post:
19-04-2019 #2
Sorry, always closed = zero resistance, I was expecting to get a reading of 1 with the spindle off in mach3 and 0 when turned on. I did at one point get the VFD to start the motor when power was turned off to my control box but that isn't much use! And yes a chinese huanyang VFD. I have it working fine on manuak with PD001 set at 0.
I live in Preston but my workshop is in Chorley.
The Following User Says Thank You to ngwagwa For This Useful Post:
19-04-2019 #3
A reading of 1?, okay, gonna ignore that and keep with the "always closed" statement - so the Spindle V5 card isn't actuating the CW/CCW outputs?, that sounds more like an integration issue between the SpindleV5 and the controlling PC/Mach3.
Step forward a bit to where they are working, and you couple the N/O CW output and ground between the VFD FOR and DCM pins, then set PD001 to 1 and that's your motor on/off control, and the 0-10V I think you've got working onto the VI input and set the PD001 to 1. And Bobs your uncle.
Looking at the Spindle V5 manual - this takes a Step/Dir input from a BoB - which clearly is set up okay, but it also expects a digital output from the BoB to actuate the Run control - which I'm guessing is what the Spindle V5 uses to drive either CCW or CW output relays. For that - check that the RUN input on the Spindle V5 is connected to a discrete output on the BoB, and that is bound to an output number in Mach3, and that output is specified in the Spindle Control page on Mach3. Details in the user manual. The goal here must be to get the CW relay switching.
Chorley?, 8 miles down the road. Some decent micro bars. Not far to travel. Only down side was I met my wife from thereLast edited by Doddy; 19-04-2019 at 05:49 PM. Reason: correction to the board names
19-04-2019 #4
That's right - the spindleV5 is controlling the speed but the on/off is controlled via the Sprint 400. Don't ask me why it was done that way.
Instead of getting the CW relay switch working would it not be easier to use the BOB spindle output?
micro bars as in ale houses?
EDIT: by the way putting the original spindle back on is looking less likely each day :)Last edited by ngwagwa; 19-04-2019 at 05:56 PM.
The Following 2 Users Say Thank You to ngwagwa For This Useful Post:
19-04-2019 #5
The only point with the Spindle providing On/Off is the CW/CCW control - if you think you'll use reverse.
You could use the BoB spindle output - it's just another discrete output, but you'll lose the reversing option (assuming the SpindleV5 does 0-10 and separately CW/CCW depending on the DIR input).
19-04-2019 #6
Don't expect to want reverse and using the BOB spindle output seems easier than trying to activate the Spindle V5 CW/CCW relays.
20-04-2019 #7
Now I am confused. Pins 16 & 17 (spindle on/dir) go from BOB to spindle 5 board but it's the sprint that starts the spindle and I can't see how the sprint gets a signal to start the motor.
NEW MEMBER: A New Addition - Time Served Engineer from Gloucestershire
By Parallel Precision Ltd in forum New Member IntroductionsReplies: 3Last Post: 10-05-2018, 12:28 PM -
NEW MEMBER: Just a quick hello
By GoBo in forum New Member IntroductionsReplies: 2Last Post: 16-12-2014, 10:13 PM -
Quick bit of help
By amxen in forum General DiscussionReplies: 9Last Post: 29-08-2014, 10:58 PM -
a 4th axis... and quick
By kingcreaky in forum Marketplace DiscussionReplies: 5Last Post: 29-10-2013, 11:34 AM -
Quick question
By m.marino in forum General DiscussionReplies: 2Last Post: 18-02-2011, 04:30 PM
