    That's right - the spindleV5 is controlling the speed but the on/off is controlled via the Sprint 400. Don't ask me why it was done that way.
    Instead of getting the CW relay switch working would it not be easier to use the BOB spindle output?
    micro bars as in ale houses?
    EDIT: by the way putting the original spindle back on is looking less likely each day :)
  2. The Following 2 Users Say Thank You to ngwagwa For This Useful Post:
  3. #2
    The only point with the Spindle providing On/Off is the CW/CCW control - if you think you'll use reverse.
    You could use the BoB spindle output - it's just another discrete output, but you'll lose the reversing option (assuming the SpindleV5 does 0-10 and separately CW/CCW depending on the DIR input).
  4. The Following 2 Users Say Thank You to Doddy For This Useful Post:
  5. #3
    Don't expect to want reverse and using the BOB spindle output seems easier than trying to activate the Spindle V5 CW/CCW relays.
  6. The Following 2 Users Say Thank You to ngwagwa For This Useful Post:
  7. #4
    Now I am confused. Pins 16 & 17 (spindle on/dir) go from BOB to spindle 5 board but it's the sprint that starts the spindle and I can't see how the sprint gets a signal to start the motor.
  8. The Following 2 Users Say Thank You to ngwagwa For This Useful Post:
  9. #5
    My guess?, and it is a guess... the Sprint is configured such that a non-zero demand on the analogue input starts the spindle-motor. That short-cuts the need for a FOR/REV control.
    Doesn't work for the Chinese VFD. You still need to source the spindle relay outputs through the BoB (and optionally through the Spindle V5) to the VFD
  10. The Following 2 Users Say Thank You to Doddy For This Useful Post:
  11. #6
    Quote Originally Posted by ngwagwa View Post
    That's spindle PWM (or Step)/DIR, isn't it? Rather than a discrete ON(/OFF)
  12. The Following 2 Users Say Thank You to Doddy For This Useful Post:
  13. #7
    Yes
  14. The Following 2 Users Say Thank You to ngwagwa For This Useful Post:
  15. #8
Name:	Screenshot 2019-04-20 at 11.11.53.png
    What's happening with Pin 5 of the Sprint controller?
  16. The Following 2 Users Say Thank You to Doddy For This Useful Post:
  1. NEW MEMBER: A New Addition - Time Served Engineer from Gloucestershire
    By Parallel Precision Ltd in forum New Member Introductions
    Last Post: 10-05-2018, 12:28 PM
  2. NEW MEMBER: Just a quick hello
    By GoBo in forum New Member Introductions
    Last Post: 16-12-2014, 10:13 PM
  3. Quick bit of help
    By amxen in forum General Discussion
    Last Post: 29-08-2014, 10:58 PM
  4. a 4th axis... and quick
    By kingcreaky in forum Marketplace Discussion
    Last Post: 29-10-2013, 11:34 AM
  5. Quick question
    By m.marino in forum General Discussion
    Last Post: 18-02-2011, 04:30 PM
