Something which sometimes makes a difference is to separate the mains supply to your VFD and control system.
Try running your VFD from an extension lead plugged into the farthest possible socket from that which is feeding your control system.
You could try swapping your E stop cables for twisted pair which are less susceptible to interference than straight cables.You think that's too expensive? You're not a Model Engineer are you? :D
Setting up new spindle
By Hercules in forum Generic Chinese SpindlesReplies: 3Last Post: 10-12-2019, 01:18 AM -
What is the best way to Test a chines machine?
By cnclover in forum Chinese MachinesReplies: 10Last Post: 27-07-2019, 07:13 AM -
setting axis A in spindle mode
By ladybreaker in forum Artsoft Mach (3 & 4)Replies: 9Last Post: 09-12-2018, 11:35 AM -
Chines CnC ebay
By amxen in forum General DiscussionReplies: 11Last Post: 01-02-2015, 03:46 PM -
setting up Moeller VFD to chinese spindle
By routercnc in forum Spindles & Drive MotorsReplies: 16Last Post: 16-02-2011, 08:22 PM
