Thread: New member lots to learn
Hi my name is Chris and I am new to CNC. I don't have an engineering background but I have always been interested in engineering and manufacturing.
I am bullding a 4' x 2' cnc router moving gantry design. I'm aiming to cut wood plastic and occasionally aluminium. I know I've made some purchasing mistakes such as 5 mm pitch ball screws that means it will run slow but I've decided to live with this. As far as the build goes the mechanics are nearly done and i have purchased three low inductance nema 34 stepper motors for x and y (motors for moving gantry will be slaved). I have a nema 23 for z axis. I'm aiming for direct drive of the ball screws. I have already purchased a CS labs IPM controller. Next task is to decide between Mach 3 or 4 and to buy suitable stepper motor drivers and a power supply.
Inevitably I would welcome any advice on my build. Thanks in advance ....Chris
The Following 2 Users Say Thank You to chillybo For This Useful Post:
14-04-2019 #2
Welcome Chris!
If you use toothed belt drive from your steppers to your ball screws you can get the movement speed you want with pulley ratios.
I don't have a gantry machine, but if I did I'd couple the screws with pulleys and a belt to eliminate any chance of them getting out of step ;-)You think that's too expensive? You're not a Model Engineer are you? :D
The Following 2 Users Say Thank You to magicniner For This Useful Post:
15-04-2019 #3
I have got it rigged at the minute with a crude belt drive to drive the gantry ball screws (so i can move gantry up and down with a power drill while im building it). I have considered running it from one motor but when i move the timing belt (20mm wide 8mm tooth pitch) manually there seems to be to much resistance. Hence why im thinking of direct drive and slave method. If i do choose the latter im thinking of putting a thinner timing belt at the far ends of the ball screw just to mechanical sync the ball screws in addition to electronically slaving the motors (this would be a safety / gantry allignment consideration).
15-04-2019 #4
I'm not a model engineer. I am building the machine as a hobby and eventually manufacture some ideas to see if I can sell them as a sideline / hobby.
15-04-2019 #5
The Following 2 Users Say Thank You to AndyUK For This Useful Post:
15-04-2019 #6
Work area is a bit untidy at the moment
FOR SALE: Lots of 1.23Nm and 1.0Nm Nema 23 stepper motors
By Jonathan in forum Items For SaleReplies: 0Last Post: 29-12-2016, 02:19 PM -
lots of help needed here
By terry1956 in forum CAD & CAM SoftwareReplies: 2Last Post: 01-08-2016, 12:34 PM -
RFQ: Looking for a reliable CNC prototyper in aluminium, for lots and lots of jobs
By Felix.U in forum Projects, Jobs & RequestsReplies: 0Last Post: 01-12-2015, 02:00 PM -
NEW MEMBER: New Member desperate to learn
By Mill Grav Newbie in forum New Member IntroductionsReplies: 3Last Post: 24-04-2012, 01:17 PM -
NEW MEMBER: lots of questions
By jsa2001 in forum New Member IntroductionsReplies: 13Last Post: 01-10-2009, 09:09 AM
