Thread: New member lots to learn
*head in hands* My mother-in-law has the same rainbow drawers - just seeing them makes me nervous about what her next 'job card' entails.
Looks like you've made some serious progress there - and your workshop is far tidier than mine I can assure you!! What are the dimensions of the machine? Looks like its got a decent amount of Z clearance.
As Clive mentioned though, you may find that a single beefier motor (I'm thinking Nema34 > 8nm) will be more appropriate with the belt drive. If they're physically connected, you won't loose sync between the screws, and you don't want to get into a situation where the motors are fighting each other.
Dropping the slave motor potentially frees up an axis and saves you buying another motor driver - it might also make a homing routine less confusing!
The Following 2 Users Say Thank You to AndyUK For This Useful Post:
15-04-2019 #2
Z axis travel is about 130mm. I can adjust the clearance by sliding the assembly up or down the gantry uprights (the benefits of extrusion). Ive built it so I can either use a belt as you suggest or slave it without any new modification. I think your right about using the belt. Only issue is I've only got 4.6 Nm Nema 34's. I could give it a try and see if one can move the gantry ok. If not Id have to splash out on a bigger stepper motor and then id have 2 spare motors.
The Following 2 Users Say Thank You to chillybo For This Useful Post:
15-04-2019 #3
BTW its a 4x2 foot machine (roughly)
15-04-2019 #4
The Following 2 Users Say Thank You to Clive S For This Useful Post:
16-04-2019 #5
From the original post you made the statement that 5mm pitch will give you slow rapids. What Voltage do you plan on running this at? As mine is running on slightly more than 60V and is capable of doing 27m/min rapids fully stable. I agree with the other statements that you use either a belt drive or two motor working in sync but never both. Good luck on the build.
MichaelSoftware SolidWorks 2024, Onshape, Aspire v9.5, Blender
CNC Machine: http://www.mycncuk.com/threads/3661-...Second-machine
3D printers both FDM/FFD and MSLA resin
CSWA &CSWA-AM certified
www.marino-customs.com
The Following User Says Thank You to m.marino For This Useful Post:
16-04-2019 #6
I'l be honest at this point. Electronics are my weak point when it comes to building this machine. I know that low inductance stepper motors can potentially run faster than higher inductance ones. As for what power to run the machine at Im guessing that depends on the power supply output voltage. I really need to build my knowledge around the electrics side. I have yet to purchase stepper drivers and a power supply, control cabinet limit switches etc so any advice would be really appreciated.
regards Chris
17-04-2019 #7
Okay, time for me to pay a bit of my debt forward.
1) Stepper motors have a sweet spot on Voltage. In reality it is a sweet band of voltage that will allow it to operate at it's highest speeds while keeping accurate steps. The formula for that is one of two they are as follows (with examples):
A) \sqrt{I} * 1000. Where I = the inductance of the motor (normally in milliHenries) Which would look like this for an equation 3.2mH 0.032 \sqrt{0.0032}*1000. That equals .0565685 * 1000. Which gives you a rough voltage of 56.57V for optimum usage of the current that the motor will demand. Thereby avoiding coil saturation and the problems that is caused by that issue.
B) \sqrt{I}(ignoring mH) * 32 (interestingly very near the square root of 1000). That get you this \sqrt{3.2}*32. Which gets you 1.78885*32 and that in turn gives you 57.24V as a safety margin. Both of these equations where written to include safety margins. Studying the engineering texts of the 1920's to the 1950's is fun. Brain draining but fun. The electrical texts need a glass of wine or two for those who are not well taught in the various strangeness that is electricity. I hold a full permit from the UK government in amateur radio and still take a glass of wine ( The UK is considered to have one of the toughest amateur radio tests for intermediate and full license permits).
So the above will help you with the Voltage. Current is another issue completely. A motor is under it's heaviest load in two main conditions. First is when it is holding a position against other motion going on (Cutting a straight line and the non cutting axis holding it's position accurately). The other is when under full dynamic load. That area i will leave to someone who understand that side of the motor better than I. As it happens during cutting but not all the time during cutting and is something that I under the function of better then the physics of.
Limits switches and such should be shielded. Full stop. I have dealt with the nightmare of them not being shielded it is not worth it. Also if possible run at 12 to 24 volts (24V is better, as less chance of stray signal noise affecting the switches and giving a false trigger.
While you are thinking about this realize that your tooling expenses can easily reach to over half the amount you put into the machine and many times much more. Don't cut corners on quality with bits it will affect your finished product.
Power Supplies can be bought or built. RSGB (Radio Society of Great Britain) has a couple of really good books on building them and there are folks here who can help as well as well as diagrams on some of the build threads. While it requires safety and understanding it is NOT as difficult as many think it is. Link to their shop page here: https://rsgbshop.org/acatalog/Online...chnical_6.html
I hope this helps you and anyone else that needs a hand on setting things up. I had a lot of help from folks here and a few other sites and paying it forward is the best I can do.Software SolidWorks 2024, Onshape, Aspire v9.5, Blender
The Following 2 Users Say Thank You to m.marino For This Useful Post:
FOR SALE: Lots of 1.23Nm and 1.0Nm Nema 23 stepper motors
By Jonathan in forum Items For SaleReplies: 0Last Post: 29-12-2016, 02:19 PM -
lots of help needed here
By terry1956 in forum CAD & CAM SoftwareReplies: 2Last Post: 01-08-2016, 12:34 PM -
RFQ: Looking for a reliable CNC prototyper in aluminium, for lots and lots of jobs
By Felix.U in forum Projects, Jobs & RequestsReplies: 0Last Post: 01-12-2015, 02:00 PM -
NEW MEMBER: New Member desperate to learn
By Mill Grav Newbie in forum New Member IntroductionsReplies: 3Last Post: 24-04-2012, 01:17 PM -
NEW MEMBER: lots of questions
By jsa2001 in forum New Member IntroductionsReplies: 13Last Post: 01-10-2009, 09:09 AM
