Thread: New member lots to learn
Thanks Michael. Ive started my research by watching this
https://www.youtube.com/watch?v=lTtYkofw-Jg
The search continues for an unregulated toroidal PSU
Regards Chris
The Following User Says Thank You to chillybo For This Useful Post:
22-04-2019 #2
Take a look at Joes build and power supply https://www.youtube.com/watch?v=4OoQ...zD30sZjtp_VyqY
23-04-2019 #3
's
Thanks Clive, I've watched a lot of Joe's Youtube videos. He has put a lot of work into his machine. If I was to build my own unregulated power supply to match my Nema 34's (4.6nm) that each have 3.4 mh inductance I have worked out that the 'sweet spot' voltage would be around 59 volts. Should I be looking at something like this when I buy the toroidal transformer.
https://www.amazon.co.uk/dp/B00MWQDI...4-e511ab4d5346 ? or this that has a higher current (and price) https://www.amazon.co.uk/dp/B00MWQDO...1ab4d5346&th=1
Then the two 30 volt outputs would be connected in series to give 60 volts. I've looked at a few Youtube tutorials but i've still got lots to learn.
Regards ChrisLast edited by chillybo; 23-04-2019 at 01:39 AM.
23-04-2019 #4
Chris you might want to look here:
https://airlinktransformers.com/cate...60%2B60&va=500
As the prices from Amazon are a good bit higher then theirs and they are UK based. So you might want to check them out. Save you a good bit of money as well as have a UK based company to back the quality of build.
MichaelSoftware SolidWorks 2024, Onshape, Aspire v9.5, Blender
CNC Machine: http://www.mycncuk.com/threads/3661-...Second-machine
3D printers both FDM/FFD and MSLA resin
CSWA &CSWA-AM certified
www.marino-customs.com
25-04-2019 #5
Thanks Michael for pointing me in this direction I did a bit of a google search but did not find this company. They certainly have a wide range of products that are competitively priced. I'm sure I will be using them. I have just watched this Youtube material to expand my knowledge. https://www.youtube.com/watch?v=CAYKno16weE
The chap seems to explain thing quite clearly.
Regards Chris
23-04-2019 #6
25-04-2019 #7
Hi Clive I'm sure your right about how nema 23's would have been more than sufficient. I think my choices could certainly have been better but at the time they were based on an eagerness to get started combined with limited time to research due to other study and work commitments. Also I intended to build a slightly bigger machine but later decided to scale it down. I am now in position where I am committed and can't change where i am with the project so I want to try and make it work as best as possible with the assets I have. I am pondering how other than overspending are there any detrimental effects that I can expect from using nema 34's on my machines functionality?
Regards Chris
FOR SALE: Lots of 1.23Nm and 1.0Nm Nema 23 stepper motors
By Jonathan in forum Items For SaleReplies: 0Last Post: 29-12-2016, 02:19 PM -
lots of help needed here
By terry1956 in forum CAD & CAM SoftwareReplies: 2Last Post: 01-08-2016, 12:34 PM -
RFQ: Looking for a reliable CNC prototyper in aluminium, for lots and lots of jobs
By Felix.U in forum Projects, Jobs & RequestsReplies: 0Last Post: 01-12-2015, 02:00 PM -
NEW MEMBER: New Member desperate to learn
By Mill Grav Newbie in forum New Member IntroductionsReplies: 3Last Post: 24-04-2012, 01:17 PM -
NEW MEMBER: lots of questions
By jsa2001 in forum New Member IntroductionsReplies: 13Last Post: 01-10-2009, 09:09 AM
